Twin Stick Transfer case
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badger, Sep 27, 2012.
  1. Oct 10, 2012 at 10:27 AM
    #121
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    so to conclude - since you don't have the unlimited time or money to do it and no one else does either or doesn't think its possible at all to begin with - i think this myth is busted. NOT POSSIBLE :)
  2. Oct 10, 2012 at 10:27 AM
    #122
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    mines sittin in El Tacorojo's garage just chillin there collecting dust
  3. Oct 10, 2012 at 10:28 AM
    #123
    Large
    Large Red
    Thus concluding the troll theory.
  4. Oct 10, 2012 at 10:39 AM
    #124
    shemp
    shemp Well-Known Member
    However, I still don't like the words "not possible". IMO, I could make it manual shift for about $10 + a few hours of labor + a bunch of old junk from my "spare parts" heap like a pair of outboard motor throttle/shift cables + handle. Of course, what you'd get out of that would be ugly as hell and would spray gear oil everywhere. It might physically compromise the shift forks as well (I would have to look at them in detail to determine this).
    Super cheap (but really crappy) way: open case, remove clips on sliding shaft to allow both forks to move independently, drill two smallish holes in the back of the case, insert outboard motor cables, drill hole THROUGH middle of 2/4 shift fork through which to pass the L/H cable, affix ends of cables to shift forks, reassemble. Route cables up into cab and mount the outboard motor control handle. BTW: I'm talking about the OLD style outboard motor handle with separate levers for shift and throttle.
  5. Oct 10, 2012 at 10:40 AM
    #125
    shemp
    This does not require **unlimited** time or money, therefore VERY possible.
  6. Oct 10, 2012 at 10:52 AM
    #126
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    prerunner to 4x4 conversion? or would it be easier to install a FJ case :D
  7. Oct 10, 2012 at 10:58 AM
    #127
    wrmathis
    Bonaire, GA
    parts and stuff
    too much work to do the prerunner to 4x4 conversion on the 2nd gen. wyatt did one and had to fab up a new crossmember. but if u wanted to do that, i'd go with a fj case.
  8. Oct 10, 2012 at 11:01 AM
    #128
    shemp
    PSU Taco85 has provided me some pictures of the ADD actuator. Looks like the problem is that the seal is failing on them. This unit is easily disassembled. It has a small bi-directional motor that operates a worm gear. It looks like the motor itself is being contaminated by salt water, in addition, it is possible for the limiter switch contacts to be contaminated. The contacts are easily cleaned, and the motor may or may not be salvageable on a case-by-case basis. If the motor is seized, I would first try to soak it for a while in a light penetrating oil, then gently try to turn it. With some luck, it may come back to life. Or maybe not.
    It might be advisable to perform some preventative maintenance on the unit if yours is still operational, since it is so easily disassembled. Clean it, spray it down with a light oil, and seal it up really good with the best kind of sealer you can get your hands on. It looks like a "greased o-ring" type seal from factory.
  9. Oct 10, 2012 at 11:07 AM
    #129
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Someone should create a separate thread for the ADD actuator, I think it's worth discussing further. With the right pointers/instructions I'd be interested in doing PM on mine.
    As for the twin stick xfer case. I'm definitely giving Wyatt a call if I have problems with my 4WD actuator. I've read here from other TW members that the estimates from Toyota dealers are like $1,300 to fix a bad actuator! :eek:
  10. Oct 10, 2012 at 11:10 AM
    #130
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    the crossmember would be the easy part ;) haha
    is there like a big warehouse full of old FJ cases somewhere? :laugh: There cant be THAT many people upgrading their tcases on their fjs can there?!
  11. Oct 10, 2012 at 11:18 AM
    #131
    shemp
    I would think that its mostly crash part-outs. That is one of the big questions that got me to thinking about modding the Tacoma case. With the Tacoma case, there is no question of availability since there is already one on your truck. I honestly have no idea about the supply of parts like this.
  12. Oct 10, 2012 at 11:41 AM
    #132
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    Ummmmmm... yeah aboot that eh
  13. Oct 10, 2012 at 11:47 AM
    #133
    Round II
    Round II Member #12005
    :cool:
  14. Oct 10, 2012 at 11:51 AM
    #134
    Round II
    Yea and not sure where my OEM TC ended up?
  15. Oct 10, 2012 at 11:55 AM
    #135
    wrmathis
    Bonaire, GA
    parts and stuff
  16. Oct 10, 2012 at 12:21 PM
    #136
    awsumdc
    awsumdc Well-Known Member
    O.C. Cali
    SASED '05 Taco
    SAS, crawler box, 14" coilover shocks, 39.5 tires,dual batteries, and a bunch of other stuff
    No need for me to send you anything. I know how it works and spent my time and money figuring it out.
    You on the other hand are just working on theories. Your comments on the two FJ shafts again tell me you've never had one of these cases apart. You have no clue how these cases actually work.
    I've had them both apart time and again looking for better ways to do things and for ways to make them better or stronger.
    I've actually applied my theories on REAL working models. And they have proven to work.
    Like I said before. YOU put your money where your mouth and finger tips are. I've done my home work already.
    There are three types of people in this world
    Those that want to do something and never do
    Those that talk about doing something and never do
    And those who do it and them talk about it
    Guess which one you appear to be
    But please. Prove me wrong. But do it on your dime.
    Here is my theory in action
    http://www.youtube.com/watch?v=LiGNkBG6eAg
  17. Oct 10, 2012 at 1:38 PM
    #137
    EL TACOROJO
    BURRY
    south mills NORCAK
    :clapping:
  18. Oct 11, 2012 at 6:30 AM
    #138
    Round II
    Damn Wyatt!:popcorn:
  19. Oct 11, 2012 at 6:37 AM
    #139
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    ::applause::
    RST FTMFW! :cool:
  20. Oct 11, 2012 at 8:41 AM
    #140
    shemp
    You obviously don't know how to read, or something to that effect. In any case, you're obviously a close-minded prick, so I'm done here.
