Twin turbo 1gr on a hilux
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hiilux, Mar 30, 2024.
  1. Apr 5, 2024 at 7:44 AM
    #61
    Hiilux
    Hiilux [OP] Well-Known Member
    E
    1976 hilux 1gr engine
    Twin turbo
    Lol right but also for those naked skeleton race cars like Cleetus cars.
    Torspd likes this.
  2. May 25, 2024 at 10:20 AM
    #62
    Hiilux
    E
    Twin turbo
    Finally out the garage after 2 years.
  3. May 25, 2024 at 1:03 PM
    #63
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
    Badass.
    BabyBilly likes this.
  4. May 26, 2024 at 9:30 AM
    #64
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I am quite excited for you mate. This thing is turning out fantastically.
    Captain4x4, Hiilux[OP] and BabyBilly like this.
  5. May 27, 2024 at 6:40 AM
    #65
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    In that above photo, it looks like there is such a large amount of room. Plenty for the intercooler and radiator.
    Have you got the front suspension on in that photo, or is it still on the wooden blocks from the earlier photo?
  6. May 27, 2024 at 6:44 AM
    #66
    Hiilux
    E
    Twin turbo
    It is sitting on the wood blocks you saw earlier. It does look miss leading the very front of the truck is at the end of the chassis. Is about 6.5 inches from the engine.
    Captain4x4 and Torspd[QUOTED] like this.
  7. Aug 30, 2024 at 1:44 PM
    #67
    Hiilux
    E
    Twin turbo
    Looking to start it soon just have one question about the cam gear. Does anyone know the angles for the cam pickup angles? @Torspd?
  8. Aug 30, 2024 at 2:04 PM
    #68
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    :nuclear:
    PhoS and Hiilux[OP] like this.
  9. Aug 31, 2024 at 6:14 AM
    #69
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I am curious what you need to know the angles of the cam gears for?
    What are you using for tuning?
  10. Aug 31, 2024 at 6:18 AM
    #70
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Jon64l likes this.
  11. Aug 31, 2024 at 6:19 AM
    #71
    Hiilux
    E
    Twin turbo
    @Torspd I need the angles “duration” for cam synk in order to run fully sequential injectors.
  12. Aug 31, 2024 at 6:26 AM
    #72
    Hiilux
    E
    Twin turbo
    Fueltech as a Cam decoder but i would have to start it first. Then run the decoder. I want to start it with the cam synk on. If i cant find the answer i might just have to do that.
    Torspd likes this.
  13. Aug 31, 2024 at 6:31 AM
    #73
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'll start with this. I'll have to look for the phase angle. Pretty sure that I dont have documentation on the angle of the cams in relation to the crank (like if using a degree wheel). As tired as I am right now, I am not even exactly sure what you're needing because I can't think of ever needing anything more than phase angle, crank position, and home position(passenger intake cam and which way the cam rotates.) But I'll help with what I can.
    Maybe this will help get you in a ballpark?
    PhoS likes this.
  14. Aug 31, 2024 at 6:36 AM
    #74
    Hiilux
    E
    Twin turbo
    @Torspd thanks for the info. I am looking for the actual duration of the cam sensor where it requires before it drops . In other words the angles in the metal piece in front of the cam gear.
  15. Aug 31, 2024 at 6:38 AM
    #75
    Hiilux
    E
    Twin turbo
    Here is an example of the info. This is for a 2jz.
  16. Aug 31, 2024 at 7:21 AM
    #76
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I have some Picoscope captures, I may be able to get what you need.
  17. Aug 31, 2024 at 7:24 AM
    #77
    Hiilux
    E
    Twin turbo
    Dont go out your way i was hoping someone here had the info. Like I said i can get it started without the cam sensor then do the cam decoder. Just wanted to be ahead.. I appreciate it though.
    Dm93[QUOTED] likes this.
  18. Aug 31, 2024 at 7:55 AM
    #78
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The Pico software can easily make degree calculations based on known references, I just need to find TDC on the crank sensor signal.
    I'll take a look tonight if I have time and see what I can come up with.
    Hiilux[QUOTED][OP] likes this.
  19. Aug 31, 2024 at 8:01 AM
    #79
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    These should do it.
    TacoLeeSD, Hiilux[OP] and Dm93 like this.
  20. Aug 31, 2024 at 8:11 AM
    #80
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's the can specs but I think what he is looking for is where the rising and falling edges of the trigger wheel fall in degrees so he can sync the cam signals with the crank signal.
    JustDSM and Hiilux[OP] like this.
