Twin turbo 1gr on a hilux
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hiilux, Mar 30, 2024.
  1. Aug 31, 2024 at 8:17 AM
    #81
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  2. Aug 31, 2024 at 8:19 AM
    #82
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I might have something on the laptop for the haltech tune. Not sure about the cams though. Only the crank for certain.
    Hiilux[OP] and Dm93[QUOTED] like this.
  3. Aug 31, 2024 at 8:23 AM
    #83
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If you can get me a reference position on the crank sensor signal for TDC I should be able to find reference the cam timing.
    Hiilux[OP] and Torspd[QUOTED] like this.
  4. Aug 31, 2024 at 9:33 AM
    #84
    Hiilux
    Hiilux [OP] Well-Known Member
    E
    1976 hilux 1gr engine
    Twin turbo
    You are correct that is exactly what I am looking for. Maybe I was explaining it incorrectly.
  5. Aug 31, 2024 at 9:34 AM
    #85
    Hiilux
    E
    Twin turbo
    I appreciate that, thanks
  6. Aug 31, 2024 at 1:34 PM
    #86
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I went out of town without my laptop. I will have it later, and will share what I can.
    Dm93 likes this.
  7. Aug 31, 2024 at 1:40 PM
    #87
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I always find the positioning just by turning off the fuel injectors in NSP and putting a timing light on it. Adjust the value until it lines up to zero
    Hiilux[OP] likes this.
  8. Aug 31, 2024 at 7:57 PM
    #88
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea my pressure transducer is at work, I have a reference to where the #1 coil fires but I'm not sure where the true TDC is in the crank signal (The sync notch I'm pretty certain isn't at TDC no 1). I think the coil fires at about 18 degrees BTDC at idle but I'm not 100% on that.
  9. Aug 31, 2024 at 8:09 PM
    #89
    caribe makaira
    Caribbean, Puerto Rico
  10. Sep 1, 2024 at 6:04 AM
    #90
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  11. Sep 1, 2024 at 6:41 AM
    #91
    Hiilux
    E
    Twin turbo
    Is that for crank signal?
  12. Sep 1, 2024 at 7:49 AM
    #92
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Not sure how to interpret that, how are you getting 60 trigger teeth when the 4.0 crank is 36 -2?
  13. Sep 1, 2024 at 7:51 AM
    #93
    Hiilux
    E
    Twin turbo
    My thoughts exactly… unless he has an aftermarket crank wheel.
  14. Sep 1, 2024 at 8:00 AM
    #94
    Speedytech7
    Those boxes are grayed out because he picked one GR from the drop-down menu. Look to the right of the drop-down menu. It has the right tooth count and missing tooth count listed there. However the crank angle which is what he's trying to show you isn't a greyed out box so it appears to be 525°. The greyed out boxes are only available if you choose a generic missing tooth trigger and put in the tooth count yourself.
    Dm93 and Torspd like this.
  15. Sep 1, 2024 at 8:02 AM
    #95
    Hiilux
    E
    Twin turbo
    I see now..
  16. Sep 1, 2024 at 8:15 AM
    #96
    Hiilux
    E
    Twin turbo
    This is my set up screen for the fueltech..
  17. Sep 1, 2024 at 8:18 AM
    #97
    Speedytech7
    I don't really know anything about fuel tech. I've only done megasquirt and Haltech. But I'd wager you just need to set crank index position to 525°. I'm not sure what that tooth count thing after it is so if that has a zero position that might be the right position initially
    Torspd likes this.
  18. Sep 1, 2024 at 8:22 AM
    #98
    Hiilux
    E
    Twin turbo
    The tooth count is auto calculated. Once i crank it and dial it in I’ll post the right crank values for the fueltech.
    Speedytech7[QUOTED] likes this.
  19. Sep 1, 2024 at 9:47 AM
    #99
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I guess what I need to know is what tooth of the crank reluctor to reference as 0 degrees to calculate the cam reluctor rising and falling edge positions.
  20. Sep 1, 2024 at 10:13 AM
    #100
    Speedytech7
    I just do the practial check after setting these things. Turn injectors off and crank with a timing light. I don't think it's worth wasting more time on.
    Torspd and Hiilux[OP] like this.
