Twisty frame question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bfk, Dec 27, 2018.
  1. Dec 27, 2018 at 7:30 PM
    bfk
    bfk [OP] Member
    AT around 7 minutes they talk about Tacoma having an independent frame from the cab. I plan on adding bed stiffeners since ill be putting on a full-size cvt tent. Would the bed stiffeners go against how Toyota has designed this bed to move during off road?
    https://www.youtube.com/watch?v=E9n31MZoqQw#action=share
    Tocamo likes this.
  2. Dec 27, 2018 at 7:31 PM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    Tacoma claims this was for better articulation, and the video showed evidence of that.
    NickleCityTaco likes this.
  3. Dec 27, 2018 at 7:37 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Which came first, the chicken or the egg? Did they design the frame for weight and cost reasons, discover it ‘warped more’ and marketing labeled it ‘articulation’? Or did they want more articulation and a less rigid frame was easier than more complex suspension?
    Sweets and Lawfarin like this.
  4. Dec 27, 2018 at 7:44 PM
    bfk
    bfk [OP] Member
    Agreed but do bed stiffness interfere with there design?
  5. Dec 27, 2018 at 7:45 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    No
  6. Dec 27, 2018 at 7:54 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No. Bed is attached to frame so will not mess anything up.
    There is a reason there is a crack between beds and cabs lol.
    synaps3 and GillyLink like this.
  7. Dec 27, 2018 at 8:02 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Sounds like nonsense to me. Maybe the shocks are just longer on the Taco. Or maybe they just made up the articulation excuse as a reason to make the frame cheaper.
    Joe23, BassAckwards, jmneill and 3 others like this.
  8. Dec 27, 2018 at 8:10 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Boxed vs C channel. Designed that way for that reason.
    Why would you think it was bullshit? It's right there in the video.
    Lurker., NickleCityTaco and snickers like this.
  9. Dec 27, 2018 at 8:12 PM
    Bishop84
    Bishop84 Well-Known Member
    Toyota used to use boxed frames on everything but stopped due to cost and weight. It's just a by product now. But it doesnt mean its good or bad really.
  10. Dec 27, 2018 at 8:45 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Stiffeners for the plastic bed?
  11. Dec 27, 2018 at 8:51 PM
    Toyota09
    Toyota09 Well-Known Member
    2016 Tacoma TRD Off-Road Inferno
    Honestly the beds probably gonna break. Get a Ranger!!
    Tocamo and Joe23 like this.
  12. Dec 27, 2018 at 9:04 PM
    Tacohumper13
    Tacohumper13 IG @_.mfa_
    Menifee
    2017 TRD Off-road DCSB 4x4
    6112/5160s w/ camburg UCAs 265/70/17 wildpeaks JP8 conversion kit
  13. Dec 27, 2018 at 9:53 PM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Know anything about a Unimog’s frame? Anyway...
    The op’s question reminds me of that YouTube Dodge vs Ford frame twist test video. Our frames may be more similar to the Ford when it comes to flex, but the bed stiffeners theoretically should keep the tailgate aligned between the bedrails during full flex (like the Dodge). I have no clue if the newer Tacoma has an issue in that scenario. My 99’s bed used to twist to the point the tailgate wouldn’t open while flexed with a loaded bed.
  14. Dec 27, 2018 at 9:59 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    ^^^Toyota engineer??
    They frame isn’t boxed or unboxed for cost savings. This myth, based on nothing but speculation, needs to stop being repeated as truth. The Taco frame is boxed or unboxed for its designed purpose, which is a combination of weight savings, center of gravity, flex, truck handling, and resistance to corrosion.
    Arguably the strongest, and most expensive off-roader is the Unimog. It has an open c-channel frame, as that is the way they designed it. It certainly didn’t make it any cheaper!
    Jaque8 and Flatout110 like this.
  15. Dec 27, 2018 at 10:28 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    They articulate pretty well after a few years on salty roads:
  16. Dec 28, 2018 at 3:39 AM
    jowybyo
    Joe
    Baltimore, MD
    Cost, weight. I’m not taking the word of some weird dude in a random video. I get that the C channel isn’t as stiff but I’d be pretty surprised if they intentionally designed it that why just for more articulation. Also, it’s a pretty small static load so I’d be surprised the c channel even deflected a noticeable amount more than the same sized boxed section.
    jmneill likes this.
  17. Dec 28, 2018 at 3:56 AM
    jowybyo
    Joe
    Baltimore, MD
    What makes you think when they make the product cheaper that they pass that savings on to the customer?
    ExplorHer likes this.
  18. Dec 28, 2018 at 4:48 AM
    eMKay
    eMKay Well-Known Member
    Michael
    Buffalo, NY
    2019 Cavalry Blue DCOR 6MT
    Pro Grill, roof rack, HID headlights, yellow fogs, LED high beams, trailer brake controller
    Body on frame pickup trucks with separated beds are supposed to flex, they can’t not flex. Why do auto makers try and make truck frames stiff? So they ride and handle like cars! You know what happens when they try to make a pickup frame stiff? They resonate. Google “Chevy Shake” to see what I’m talking about. You will see video after video, and post after post of people trying to fix it with tires, shocks, driveshafts with limited success. Will the Ranger do this? Probably not since it’s not a new truck, it’s 7 years old already, someone in Europe would have noticed.
  19. Dec 28, 2018 at 4:53 AM
    cipherbreaker
    cipherbreaker Well-Known Member
    I highly doubt articulation was a primary engineering objective for the Tacoma. It was definitely a byproduct of cost-savings.
    jowybyo likes this.
  20. Dec 28, 2018 at 5:37 AM
    Loudog504
    Loudog504 Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    I saw a ton of the new rangers in New Zealand recently more so than the Hilux. I saw a few all modded out with armor, snorkel, racks, etc... and they look slick. Seems to be really popular over there. My unbiased opinion is they look nice and if they are reliable (Lets be real its a ford truck) I think it will dig into the Tacoma sales. They seemed to be priced in the same line as the Tacoma's and they do look a little more modern, all be it very ford explorerish, with a lot of comparable tech inside.
    This can be some real competition for the Tacoma...which is generally good all around.
