Twitchy Steering?
Discussion in '1st Gen. Tacomas (1995-2004)' started by x2468, Oct 26, 2011.
  1. Nov 1, 2011 at 7:03 PM
    scocar
    scocar Patron of the Farts
    No, the issues you mention here are more slop that twitch (twitch meaning super sensitive, the opposite of slop). The aftermarket coils and shocks make them wonderfully responsive and provide great road feel, but as your speed increases, the tracking (tendency to go straight) goes away, and you need constant minor input to stay straight, or in your lane. The truck responds very well to input.
    Insufficient caster makes the truck feel like it is up on its toes at higher speeds. I also noticed increased understeer. That, too, has gone away with increased caster.
  2. Nov 1, 2011 at 7:29 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I suspect this depends on the truck and, more importantly, the tech. Mine was able to achieve 0' (left and right) Camber, 2.4' & 2.5' (left and right) Caster, and -0.01' & 0.02' (left and right) Toe on my truck, though it took a couple of visits...
    Take a look at your alignment numbers - you MAY be pleasantly surprised...
    BTW, I don't have any problems with my steering despite still having stock UCAs. :D
  3. Nov 1, 2011 at 7:37 PM
    scocar
    That's the first thing I look at before I leave the shop. Your numbers a great, with less caster on the driver side to keep it out of the gutter, and mine are all good, but they are...uh, in the garage right now. But dialed very well within spec.
    But now I am interested in the allegation about camber. I believe caster is the last thing they set, and I don't see how increased caster could affect camber and cause cupping. I thgout that usually cam from excessive toe-in. Of course, it's not like I have ever perfromed an alignment, so WTF do I know other than what I read and feel...
  4. Nov 1, 2011 at 10:43 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Did your tech give you the final results for all three settings?
    Edit: NVM, it helps to read all the way thru.
  5. Nov 1, 2011 at 11:08 PM
    scocar
    MIKE! What the heck! I didn't recognize the new avatar. Haven't seen you post for a while.
  6. Nov 2, 2011 at 8:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, its a self portrait... :eek:
    A lot like your is... :D
  7. Nov 6, 2011 at 4:54 AM
    x2468
    x2468 [OP] Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Nice! awesome. yeah we are def talking about the same thing if you feel it more in crosswinds. I was starting to think that the extra wheel well volume was allowing the wind to blow me around since the 881 install.
  8. Nov 6, 2011 at 9:44 AM
    scocar
    Naw, it's the caster. Granted, just the lift and having more under under the truck has an effect too. My cap makes crosswind and semi-truck blow-and-suck effect even more noticeable.
  9. Nov 6, 2011 at 1:31 PM
    x2468
    I love how the truck rails through turns with the 881/90004 combo. If I can get the bump steer to go away ill be so happy.
  10. Nov 6, 2011 at 1:42 PM
    marcchrisv
    marcchrisv Well-Known Member
    Gardnerville, NV
    99 Tacoma xtra, 2.7
    Toytec 2.5" lift., just the beginning. Front Builstein coil-overs fully adjustable from 0-3". 2" AAL in the rear with 2.5 degree shim. Total Chaos uni-ball UCA's.
    I love it. I'm constantly on the modify path, however price and time have really affected this. I also have the "bump steer" issue. I opted to go with the less tire wear and deal with the bump steer. That's just me though. If I was driving long trips, i would probably opt for better steering, and just rotate the heck out of the tires by doing full removal and swapping sides, as apposed to just front/back swaps.. Just me.. Hope this helps.
    Chris.
  11. Nov 6, 2011 at 3:41 PM
    scocar
    Yeah, I rotate them in cross-pattern myself religiously, so if it does cause more wear, it shouldn't to the point of irregularity.
    What is this extra wear you speak of, anyway? A little more edge wear from turning because they are farther forward of the steering axis?
    Anyway, if lifting it reduces a degree of caster from stock height, adding that back in after lifting shouldn't cause any more wear than standard height, I would reason.
  12. Nov 7, 2011 at 9:24 AM
    x2468
    The chef I work with is taking automotive tech classes and Im at his school trying to work out the alignment dealio. They have s hunter engineering digital imaging alignment station. I'm going to see if I can get him or is instructor to put 2.4' of castor in the left and 2.5' in the right.
  13. Nov 7, 2011 at 10:11 AM
    scocar
    That should be ideal to compensate for road camber.
  14. Nov 7, 2011 at 4:42 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Not trying to thread jack, but I didn't want to start a new thread. My truck wanders all over the road right now. Wind is terrifying to drive in and I am constantly correcting my steering. If I'm getting an alignment, should I get all 4 wheels done or save about 50 bucks and just do the front? I have no lift and run 265/70/16 in winter and 265/75/16 in the summer.
  15. Nov 7, 2011 at 4:56 PM
    #35
    scocar
    265/75/16 is fine. It's the largest you can wear without lifting.
    These trucks don't take a 4-wheel alignment. The rear is on leafs, and there is no adjustment. If it is out of whack, you have bigger problems than an alignment shop can correct.
    ffirg, do you have steering play/slop, or is it truly wandering? With the cap, you're going to catch wind. Have it aligned, and make sure they get the caster within spec, which is 1.5 to 2.5. You could also have bad toe that is causing this. Also also, are your tires the correct presure, and not overinflated?
    Also also also, if all your suspension is still stock, it could just be worn out, and this makes it even more susceptible to crosswinds, etc. Mine used to wallow and sway at highway speeds, and it scared the piss out of me, so I went off on the suspension. To start, if your shocks are original (or leaking), replace them first to see if it helps.
  16. Nov 7, 2011 at 6:34 PM
    #36
    ffirg
    mike
    Anchorage, Alaska
    My suspension is still all original factory stuff. I'm still at less than 55k miles, though I know they are worn because everything is sagging, lol. But yes there is slop/play in the steering. It does not go straight when I let go of the wheel and the wheel is off center when I'm driving straight. I've never had an alignment before, hence the questions. I was planning on replacing suspension and lifting 2 inches this summer, but with these icy/snowy roads I really don't like getting blown all over the place. Might have to do the lift around Christmas instead, and just get the alignment then.
  17. Nov 7, 2011 at 8:21 PM
    #37
    scocar
    Sounds pretty dangerous for your conditions up there. First, your wheel is not centered, and obvioulsy it doesn't want to go straight. Does it always pull to the same side when it doesn't go straight? I'd get that alignment now for two reasons:
    1. It isn't safe the way it is, especially on ice. Safety first.
    2. You should know if anything is wrong before you do a lift, because the lift can just add new issues and make it harder to figure out something else that was already a problem.
    We're talking like $50. Basic maintenance. I'd do it now. Make sure you get to Christmas, first.;)
  18. Nov 7, 2011 at 8:55 PM
    #38
    Norton
    Very sound advice! :thumbsup:
  19. Nov 7, 2011 at 8:58 PM
    #39
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    Mine is nice and tight with a nice weight to it imo it's perfect for a steering wheel the only one that I like as much maybe better than the Tacoma's is my Dad's Porsche.
  20. Nov 7, 2011 at 8:59 PM
    #40
    ffirg
    mike
    Anchorage, Alaska
    The majority of the time it pulls to the right when braking, but at highway speed it wanders left or right. I'll try to make an appointment to get it done next week if my professors/boss give me a break :( Thanks for the advice, I didn't really think of the lift causing other issues.
    I guess I have one last question. Getting an alignment now with my smaller tires on won't cause any issues when I put my slightly larger summer tires back on, will it? I don't think it will, but just wondering.
