Two 1/2" + 1/4 drivers" VS 1/2" drivers + 1/4" passenger
Discussion in 'Suspension' started by maxpower29, Mar 30, 2013.
  1. Mar 30, 2013 at 4:06 PM
    maxpower29
    maxpower29 [OP] Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    I have the Eibach coils with the 5100s set at .85 right now. I love the look but its just not enough clearance with my 285 tires, and you can tell in my sig pic. Im looking for a little more high but Im not sure what will look the best and feel the best with my 1.5 AAL in the rear. I also have 1/4" taco lean in the front, and about 1/2 lean in the rear (is that normal).
    So my options are:
    1. 1/2" + 1/4" on drivers ......... 1/2" on passenger
    2. 1/2" on drivers ................1/4" on passenger
    3. 1/4 on both driver and passenger and ignore Taco lean
    Anyone who has these setups can you please post pics or suggestions, thanks.
    Best answer will get a prize. Not sure what the prize will be yet though.....:D
  2. Mar 30, 2013 at 9:09 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    There has to be someone who has one of these setups
  3. Mar 30, 2013 at 9:21 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 70 17 cooper at3
    I just installed mine yesterday. Billy's at .85 with eibachs and 1/2" spacers. I don't have my 285 on yet so I can't tell you about clearance. I plan on changing out the passenger side spacer to 1/4". My rears are even at 24".
    Stacking spacers are not recommended and the taco lean bother me. So I vote 2.
    Hopefully I get my wheels/tires on soon. They're sitting in the kitchen. LoL
  4. Mar 30, 2013 at 9:39 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Thanks a lot. Can't wait too see the pic. So you figure you got a good 3 inches out of the lift?
  5. Mar 30, 2013 at 9:50 PM
    Asianguywithatruk
    CenCal
    05 taco DCSB
    I actually got more than I thought but hopefully they settle. I went from 19.5" from wheel center hub to fender. Got 23.5" after.
    Did you happen to measure your truck before your lift? I'm wondering if my truck is sagging before. I actually took the top nut off the coilover without a spring compressor and it didnt go flying.
  6. Mar 30, 2013 at 9:55 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Choice #2. Thats what Im rockin with 255\85's. See sig for any other details.
  7. Mar 31, 2013 at 4:58 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    No I wish I did though. I searched the site for a while for the stock hub to fender measurements but couldn't find them either.
  8. Mar 31, 2013 at 5:21 AM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    2013 DCLB SR5 4X4 Nautical Blue
    Check out my Build
    Sub'd
    I've been contemplating this
  9. Mar 31, 2013 at 7:22 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I think I'm going to go with the 1/2 inch on drivers and 1/4 inch on passenger so I don't have to stack them. I do like the look with a bit of rake though so anymore might be a bit much. Would love to see a few more pics though
  10. Mar 31, 2013 at 10:13 AM
    Devildoc
    Devildoc Well-Known Member
    Lincoln, California
    Speedway Blue off road
    Running board, K&N air filter, Nitto Terra Grapplers G2 on ProComp 7089(285/70/17), 3" front lift and 1.5" AAl rear, all with bilstein 5100's with Eibach spring, 1/2 spacer in driver side and 1/4 spacer on the passenger, Wicked Flow exhaust, Debadge, satoshi raptor grille (HomerTaco)
    I am about to do your option 2 to clear some 285's and was wondering how much rubbing you have now without your spacer? I have the same wheels and still thinking if I have to do the spacer or not. I am between 5100's with Eibach on .85 alone or with spacer. Your truck has a good stance right now not too much rake, its just right. If you do the spacer, it might just level it up and you will be good to go.
  11. Mar 31, 2013 at 10:15 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Have you considered swapping the Eibachs for OME 885's ?
  12. Mar 31, 2013 at 11:56 AM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I like the eibachs because I have the opportunity to drop the 5100s to 0 and keep the stock leveling look if ii take these wheels back off
  13. Mar 31, 2013 at 12:00 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    I had a fair amount of rubbing but then I cut lots of plastic and it's better now. I still need the cab mount chop or it will keep rubbing that when you turn and go over bumps
  14. Mar 31, 2013 at 12:10 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Silverado Z71
    Stock
    I have a DCLB with Eibachs, 5100s at .85 and a 1/4" spacer on driver's side. I'm looking at getting new rear springs and moving the 1/4" spacer to passenger and putting a 1/2" on driver's side and upping to 285s
  15. Mar 31, 2013 at 12:15 PM
    Devildoc
    Lincoln, California
    Thanks OP! Now I think I am set to do like your option 2. But still searching if 885's OME coils on .0 setting with the same spacers will be a smoother ride than sticking with the Eibach's on .85.
  16. Mar 31, 2013 at 2:15 PM
    maxpower29
    Jordan
    Nova Scotia, Canada
    Just took some measurements and they are pretty odd. Taco lean is different then most I think.
    These are from ground to fender top on a practically perfectly level ground
    Front
    Drivers = 37 1/2 "
    passenger = 37 3/4 "
    Rear
    Drivers = 39 1/2"
    Passenger = 40 "
    The rear lean is a bit noticeable. Not sure what to try to get the rear up 1/2" Toytec says the 1/2 spacer gives 3/4" lift and the 1/4" gives 1/2" lift so the front should be good. Im not sure if theres something wrong with the rear or not but its been like this for over a year now with the 5100s and not sure if it was with the stock Bilsteins because I didnt check.
