Two Bows for sale ASAP
Discussion in 'Buy / Sell / Trade - Other' started by badguybuster, May 14, 2012.
  1. May 14, 2012 at 1:02 PM
    badguybuster
    badguybuster [OP] Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    For sale ASAP.
    Martin Monster Buck Hunter: 45-60 pound adjustible draw weight, draw length adjustible from 24-29, no press needed. Just swap out cam attachments and/or tighten or loosen hex bolts. Bow has 20 arrows down range. It is the fastest bow I've ever seen. We clocked it at 330 fps using easton carbon 400's. Mint condition. Bow weighs almost nothing.
    From MARTIN-How can one describe a Monster Buck, other than light, quick and very deadly! This compact hunting bow features a reflexed riser and fully parallel limbs for performance with none of the extras... no noise, no vibration, no recoil.
    M-Pro cams, with an adjustable draw stop, delivers amazing speed from a silky smooth draw. Also a slimmer grip profile for increased comfort and improved accuracy.
    The Monster Buck utilises a super lightweight riser design and M-Pro Cams designed to perform ideally at draws ranging from 24" to 29".
    Fully parallel limbs keep the shot extremely soft though with enough energy to deliver impressive speed.
    Watch 345fps at 29" and you'll realise that big performance can come in small packages!
    Martin is one of the only companies whose limbs are built with 3 part laminate for durability, accurate temperature control, 50 tonne press and with aerospace adhesive. Makes you wonder why all manufacturers don't use this process.
    M-Pro Single Cam with Silky Smooth Draw, Shooter Friendly and No Shock or Vibration
    Double Helix Elite Strings made from BCY material for increased speed and superior strength and pre-stretched before, during and after serving.
    Bow specs at a glance
    •Weight range 5-60lbs only. All bows are adjustable 15lbs down from the peak draw weight.
    •Draw range 24"-29"
    •Let-Off 80% (optional 65%)
    •Cam New faster M-Pro Single Cam with optional draw stop
    •New light weight design
    •Limbs Coreflex Solid Straight
    •IBO Speed 345fps
    •Axle to Axle 29.75"
    •Brace height 7"
    •Mass weight 4.1lbs
    •Double Helix Elite Strings made from BCY material
    •Slim Torque Free Grip
    •Thermal V Leather Grip
    •Omega V Vibration Escape System
    •Carbon cable guard rod with Teflon slide
    •Machined aluminium riser
    •Machined aluminium limb cup
    •Standard Vibration Escape Module (VEM) Shelf Plate
    •Slimmer grip profile for increased comfort and improved accuracy
    •A Realtree APG Camo.
    I paid $699 for it new. Will sale for $400 shipped to CONUS
    Vintage Bear Archery Grizzly
    Nickel Raised Coin
    Grayling, Michigan bow
    US patent, not Canadian
    Right Hand
    50# at 27”
    52” long
    Excellent condition
    No cracks or twist
    Circa 1958 (but not 100%)
    Still shoots like a dream
    Green with brown stripes
    Needs a new string, current one is starting to fray
    value at $250
    pic to follow soon as stuped camera quits pissin me off
