Two Bullets through Engine Harness. No Fuel, Horn, or Drivers Rear window
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FiveShotTaco, Apr 23, 2020.
  1. Apr 24, 2020 at 11:12 AM
    #61
    lynyrd3
    Bill
    East Central Upstate NY
    :eek: Welcome to TW :hattip:
    :popcorn:
    FiveShotTaco[OP] likes this.
  2. Apr 24, 2020 at 9:37 PM
    #62
    mk5
    mk5 Asshat who reads books
    SoCal
    '05 access cab 4x4
    Here are some more suggestions to consider
    1. Is the trailer fuse a critical clue? Unhook your damaged trailer connector to rule that out as the source of the short. If the fuse still blows, then that tells you you probably have damage to that wiring bundle under the truck. Maybe there was a 6th shot, and that wiring caught a ricochet off the road.
    2. If you still have access to the fuel pump connector, I might suggest running a temporary wire from the relay / resistor to the fuel pump, just on the ground, to make sure the pump indeed turns on with the key. You will need to splice into the connector to do this, but it might save you from a vain search for a problem that isn't there.
    3. On the off-chance that it isn't the fuel pump wiring... check the ECU connector and pins carefully. A bullet isn't always a great wire cutting tool. Perhaps one of the wires got torn out of the crimp connector, or a pin came loose in the connector.
  3. Apr 25, 2020 at 4:36 AM
    #63
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    That's funny.. I was thinking that exact same thing yesterday afternoon. :quickdraw:
  4. Apr 25, 2020 at 7:17 AM
    #64
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Some one was mad because they couldn't master a 6 speed?
    SR-71A and cosmicfires like this.
  5. Apr 25, 2020 at 9:27 AM
    #65
    FiveShotTaco
    FiveShotTaco [OP] Active Member
    Austin
    2013 DCSB TRD Off-Road V6 6-Speed
    TRD Supercharged, Kings Suspension, 18X10 Wheels, 33" Tires, TRD CAI
    Thank you everyone for the warm welcome and great suggestions. I'm hoping to have some good news by the end of the day.
    Thanks for those!
    They're awesome. Water proof and pretty much fool proof. Some use a torch however it can easily melt the sleeve. I recommend a heat gun. You can hold it 1/4 inch away from the heat gun and it still wont get hot enough to melt the sleeve.
    Thank you for the suggestions. Very valid points made! I'll take them into account. Diving head first in the truck today. I had a family thing come up yesterday so I wasn't able to work on the truck.
    Update: Unplugged damaged trailer plug and the 30A trailer charge fuse still blows.
    I'm going to start at the resistor and probe the fuel pump wire every few feet until I don't have voltage. This way I at least can narrow down the disconnect to a specific area.
  6. Apr 25, 2020 at 11:48 AM
    #66
    FiveShotTaco
    Austin
    *UPDATE*
    Runs and drives great now! No broken wires. In the drivers kick panel there are two plugs which are identical. I had them mixed up!
    I now have drivers rear window, the trailer fuse does not blow anymore, and I have fuel.
    New Problems:
    I still don't have a horn.
    My 4-LO Lights are flashing although the truck is definitely in 2-HI.
    Traction Off light
  7. Apr 25, 2020 at 12:10 PM
    #67
    Muddinfun
    Muddinfun Well-Known Member
    Horn and airbag light are probably a result of a broken spiral cable (clock spring). If the steering shaft was disconnected that would do it. If the shaft wasn’t disconnected, but the column with switches was spun, that would break it.
    Biscuits, Skyway, Too Stroked and 3 others like this.
  8. Apr 25, 2020 at 1:07 PM
    #68
    Bushed
    Bushed Well-Known Member
    Kenora, ON
    08 DCSB TRD OR - Sold
    Cambridge Metals and Plastics Bed Bar
    Haven’t read through the whole thread @FiveShotTaco. Has anyone asked yet to see pictures of the CK parked next to the Tacoma? Or the truck next to that, which I think may be a square body? Hard to tell on this small screen.
  9. Apr 25, 2020 at 1:40 PM
    #69
    FiveShotTaco
    Austin
    Airbag lights are off now. (front seats werent plugged int)
    GOOD CALL! When the steering column was dropped to remove the dash the column with switches was probably spun.
    I sold the 70' C20 2 or 3 days ago. I plan on Swapping the 83' scottsdale with LS3/6L80E from a 2010-2015 Camaro SS if I ever decide to part with the corvette. That'll be a tough one.
  10. Apr 25, 2020 at 1:59 PM
    #70
    Muddinfun
    Glad to see you're making progress. That was a huge undertaking. It's always tough to put something back together that somebody else took apart. Good job.
    Biscuits, tcjacado and TnShooter like this.
  11. Apr 25, 2020 at 3:27 PM
    #71
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    :thumbsup: Always good to hear good news!
    Biscuits likes this.
  12. Apr 25, 2020 at 5:45 PM
    #72
    mk5
    SoCal
    '05 access cab 4x4
    Great work!
    You've got a one of a kind truck, that's for sure.
  13. Apr 25, 2020 at 8:13 PM
    #73
    ratcitypnw
    ratcitypnw New Member
    05 Tacoma 4x4 4dr
    ::clapping::
    cruxofthebisquit and Biscuits like this.
  14. Apr 26, 2020 at 4:57 AM
    #74
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    :cheers: Great to hear the good news!
  15. Jul 7, 2020 at 9:49 AM
    #75
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Update?
    CaptAmerica likes this.
  16. Jul 7, 2020 at 10:29 AM
    #76
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    GMTA.... For my 50th I had a t shirt made saying, "aged flatus." The guy who made it was Iike wtf.
    My gf was like wTf....I like it.
  17. Jul 7, 2020 at 8:22 PM
    #77
    FiveShotTaco
    Austin
    I just installed a supercharger and I'm picking up relentless fab bumpers next Friday. I still might have to replace the harness because I have the P0332 CEL after replacing the knock sensor at the same time as the supercharger install and 4WD does not work even after soldering the front actuator conductors.
  18. Jul 7, 2020 at 9:02 PM
    #78
    Biscuits
    Lol that's awesome. Shit don't work because it was used as target practice but we're gonna supercharge the hell outta it. Dude, start a build log.
    SR-71A, CaptAmerica and Jimmyh like this.
  19. Jul 8, 2020 at 8:27 AM
    #79
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Isn’t that what this thread is?
    It’s certainly the slowest episode of Overhaulin’ I’ve ever seen.
    Biscuits[QUOTED] likes this.
  20. Jul 8, 2020 at 10:44 AM
    #80
    Biscuits
