Two Dead Batteries in 3 Months?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vintage_carrot, Apr 4, 2020.
  1. Apr 4, 2020 at 11:40 AM
    vintage_carrot
    vintage_carrot [OP] Well-Known Member
    2020 SR5 DBL Long Bed
    Hey yall!
    First post, hella long lurker! Got my 2020 Double Cab Long Bed on January 1, 2020! Started the year just right!
    A month after having my taco, my truck started having a crazy tough time starting (New England). Struggle to turn over, multiple tries, didn't want to flood it. Turns out, I had a couple dead cells in an effectively new battery. Covered under warranty, got a new battery free at the dealer. Couple weeks later, I install my 12Volt Solutions car starter! No problems, awesome gadget, loved it! Now we are in April, and my car is having trouble turning over again! Really?! 2 bad batteries in not even 2 months?
    I almost certain it isn't the car starter since there would posts about it everywhere. Toyota warranty is covering the second battery too. They checked parasitic draw and it was super low they said so they didn't think that was a problem. They don't know what the problem could be and I don't either. I hope it isn't the car starter. Anyone else having problems with new tacos and bad batteries or am I just unlucky?
    Take care yall!
    TacomaGold16 likes this.
  2. Apr 4, 2020 at 11:42 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Are you draining the battery regularly?
    and by that I mean idling a lot, leaving lights on etc.
  3. Apr 4, 2020 at 11:46 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I would guess there is a problem with the charging system. I assume The Toyota tech checked that?
  4. Apr 4, 2020 at 11:54 AM
    vintage_carrot
    I don't think so, maybe I'm just not informed enough. I don't leave the lights on when the car is off, I don't idle just sitting in a turned on truck in a parking lot. I would hope they checked the charging given I told them I think it's the alternator not charging the battery.
    I just bought one of those cigarette lighter battery meters on Amazon to maybe keep track of it for like 10$.
  5. Apr 4, 2020 at 11:58 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    What is “12V Solutions Car Starter”? I’m guessing an aftermarket remote start system? If so, my money is on that being the cause of a parasitic drain. Or possibly an aftermarket alarm installed by the dealer before you purchased the truck.
    In&out and b_r_o like this.
  6. Apr 4, 2020 at 11:58 AM
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    Wow my '16 battery lasted 75,xxx miles and I just replaced it two weeks ago.
    shakerhood likes this.
  7. Apr 4, 2020 at 12:01 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Although two new batteries being bad is certainly not impossible, "I installed . . ." got my attention. If they checked the parasitic, then not sure what else, if the system is working as it should. You can't "leave the lights on" in these trucks.
    Let us know what happens.
    G.
  8. Apr 4, 2020 at 12:01 PM
    vintage_carrot
    The aftermarket car starter (12Volt Solutions) came highly recommended here on TW. They checked the parisitic drain and nothing made them concerned: Started the draw test at 0.247 milliamps and dropped to .03 after settling. Might have been something the dealer installed before I took the truck off the lot.
  9. Apr 4, 2020 at 12:07 PM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    My 2016 has less than 15,000 miles and still has the original battery.
    24-7 likes this.
  10. Apr 4, 2020 at 12:16 PM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    Is the alternator not charging the battery? What's the voltage showing when you start in the morning and when you're traveling? Should be around 14.0-14.2 starting cold and settle to 13.9 or so I believe.
    If you have a multimeter it can be helpful to test at the terminals.
    Dealers often ignore the "I think" statements when you bring in a problem, unless you explicitly ask them to test something, so best not to assume anything.
  11. Apr 4, 2020 at 12:18 PM
    vintage_carrot
    You’re right, I think statements aren’t that good for them. I just bought a battery checker for the cigarette lighter. I don’t have access to a multimeter at home since I’m effectively locked out of work.
  12. Apr 4, 2020 at 12:23 PM
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Why are you saying “hella” and “y’all” if you’re from New England? And yeah the OEM batteries suck.
    BillsSR5 likes this.
  13. Apr 4, 2020 at 12:24 PM
    vintage_carrot
    Hella because I’m a millennial and y’all because it’s the perfect word instead of everybody!
    b_r_o likes this.
  14. Apr 4, 2020 at 12:26 PM
    vintage_carrot
    The only extra, beyond 5k service, was Draw Test and replacing the battery. I feel it in bones, I’m gonna have to head back soon for them to do the charging test specifically.
  15. Apr 4, 2020 at 12:36 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    The cigarette voltage meter should work fine, just pay attention to when you start and when you're driving and if they're not good numbers then you'll know before having to take it in!
  16. Apr 4, 2020 at 12:37 PM
    vintage_carrot
    Much appreciated everyone! I just can’t stand seeing my baby truck in the hospital for coughing so much!
    will definitely keep an eye on the voltage when I get the meter and have the tech check the charging and alternator next time.
  17. Apr 4, 2020 at 12:45 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    maybe he transplanted from Alabama to New England o_O
  18. Apr 4, 2020 at 12:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Parasitic drain can be intermittent, they may have checked for it but it just wasn't present at the time.
    When chasing a drain, any aftermarket/added on electrical stuff is suspect in my opinion
    Tacoma Mike and Garyji like this.
  19. Apr 4, 2020 at 12:49 PM
    BillsSR5
    bill
    2014 SR5
    maybe you should take it back to the Dealership and let them fix it[​IMG]
    b_r_o likes this.
  20. Apr 4, 2020 at 1:01 PM
    friendlywithbears
    B
    The Wild
    2016 TRD OR MT
    You can also do rudamenrary check for parasitic drain:
    - go for a long drive to top off the battery
    - let it sit for a bit til the voltage normalizes to steady state. Note that voltage.
    - let the car sit overnight and check voltage in the morning
    If you see a strong drop in voltage then something is hungry.
