Two front wheel bearings question2...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr Chubbs, Dec 29, 2013.
  1. Dec 29, 2013 at 3:49 PM
    Mr Chubbs
    Mr Chubbs [OP] Member
    AZ
    Base
    It appears the wheel bearings assembly on my 2010 Tachoma is a sealed unit including the hub and the spindle.
    1) Is this correct?
    2) If #1 is correct, what is the expected life expectancy of the assembly?
    Great forum of knowledgeable folks!
    Thanks for all your help in advance.
    Mr Chubbs
  2. Dec 29, 2013 at 4:01 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Life expectancy will have several determining factors such as lift, wheel backspace, miles, etc. Generally a wider stance (via wheel spacers or different wheels) CAN wear bearings out faster, but it depends. I got 126k out of my 2005 dclb before i needed front bearings. My current truck is a 2010 with 44k and i dont need em yet. Front wheel bearings arent the best on these trucks but it's not really that big of a deal to replace em. If you keep your truck stock, i would think you could get 100k easy.
  3. Dec 30, 2013 at 8:19 AM
    Mr Chubbs
    AZ
    Base
    Thank you for the welcome, DoorDing!
    The hubs in your post appear to be for 4X4 and Prerunners only. My Tacoma is a "Base" model 4x2 - 100% stock. Again, I am curious as to what I can expect for bearing life. My vehicle is a 2010 and the odometer currently is right at 96,000 miles. Should I be contemplating replacing the bearing and hub assemblies in the near future?
    Thanks to all the members here for their knowledge and willingness to share! :)
    Mr Chubbs
  4. Mar 13, 2014 at 4:20 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    The fan didn't chirp. The frames didn't rust out in a few years either.
