Two kinds of Destination A/T's at same size 265/75/16 differences?
Discussion in 'Wheels & Tires' started by Soul, Jan 21, 2008.
  1. Jan 21, 2008 at 9:16 AM
    Soul
    Soul [OP] Well-Known Member
    07 PreRunner SR5 Black
    I recently call the firestone dealer they said they had two kind of A/T's in size 265/75/16. One which i s LT which they recommend goes for 159.99$ The other is a just Pmetric for 120.99$. I heard the 159.99$ is for offroading. He couldn't really give me a quick description cause they didn't have them in stock. Can any tell if they look the same and what's the primary difference?
  2. Jan 21, 2008 at 3:46 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    usually the LT's are a smidge bigger and can handle more of a load than passenger tires
  3. Jan 21, 2008 at 11:48 PM
    pdxyota
    pdxyota Well-Known Member
    Greg
    Newberg, OR
    2005 4x4 5M 2TR-FE SR5 Access Cab Indigo Ink Pearl
    TSB x 2 because first TSB leaf springs broke
    Deeper tread. Look at this link.
    P=40lbs per tire speed rating S ( Up to 112mph).
    (higher load capacity)LT=42lbs per tire speed rating R (Up to 106mph)
    Read this as well, speaks to the differences in PSI, etc.
  4. Jan 23, 2008 at 5:25 PM
    tunerperformance
    tunerperformance Member
    08 tacom xsp
    p-metric is going to be a 6 ply side wall as an lt will more than likely be an 8 ply i work for firestone and to be honest if your not towing anything stay with the p-metric if you dont you ar going to regreat it later the ride is going to be harder on an lt tire sidewall is thicker not much give
  5. Jan 24, 2008 at 4:32 PM
    pdxyota
    Greg
    Newberg, OR
    If you don't need the LT's, don't. The ride will suck a bit, especially if you get the TSB.
