Two lights one switch
Discussion in 'Lighting' started by Shadowhunter, Feb 20, 2019.
  1. Feb 20, 2019 at 7:20 PM
    Shadowhunter
    Shadowhunter [OP] Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Can I wire my lightbar and ditch lights to run off the same switch. I want both to turn both off and on at the same time. I don’t want to give up an extra switch blank to run something I could run off one switch. Both of my harnesses are relayed. My ditch light harness is 100% installed. Where and what would I splice into. I’m assuming I can splice the trigger wires together. Any help before I catch my truck on Fire?:bananadead::notsure:
  2. Feb 20, 2019 at 7:28 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    If the relay, fuse and wiring for the ditch lights will support the additional current draw then just split the output from the relay to both sets of lights. If it won’t you can either upgrade all of it so it will or split the trigger wire from current switch to two separate relays.
    vicali and Shadowhunter[OP] like this.
  3. Feb 20, 2019 at 9:10 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    What he said. I'd favor each having it's own fuse and relay but both relays can be activated by the same switch.
    Shadowhunter[OP] likes this.
