Two-piece lug nuts still used?
Discussion in 'Wheels & Tires' started by RichochetRabbit, Mar 21, 2023.
  1. Mar 21, 2023 at 10:07 PM
    RichochetRabbit
    RichochetRabbit [OP] Ping Ping Ping
    I had a 2007 Corolla. One day in Discount Tire I sat in the watching window while the technicians rotated the tires. I expected a short simple process.
    Instead the technician took 20 minutes to remove one of the 20 lug nuts, using 6 different tools both powered and manual. Plus some lube and gunk-dissolver.
    Seems in 2007 (at least that year) Toyota used a two-part lug nut, with different metals in each part. The core different from the presentation part. And I think many in TW are materials-savvy enough to know the effects of different metals heated/cooled repeatedly.
    I had to buy 20 new single-cast lug nuts to be sure I could remove any of the lugs by myself anytime.
    Has Toyota repeated this particularly spectacular maneuver?
    Discount Tire likes this.
  2. Mar 21, 2023 at 10:15 PM
    Bishop84
    Bishop84 Well-Known Member
    Toyota has used the same washer lug centric 2 piece lug nut since the 80's. So ya its the same.
    I rarely see them fail, Dodge is famous for this, but Toyota not so much.
    What happens to them is techs use the wrong socket, or a shallow on a long lug and it causes stress on the housing and they swell.
    Also if in a rust belt they can swell from corrosion.
    I wouldn't worry about it. Search lug nut problems on here and you'll see its not a common issue.
  3. Mar 21, 2023 at 10:56 PM
    RichochetRabbit
    Thanks for that
    I tried a search first, maybe not as extensive as could be but ... did not immediately bring anything up.
    Well, maybe the single-cast was a Discount Tire special, maybe they finally got some of their "courtesy rotations" money back. Either way, I did not think they put a show on for me especially to gain more money, so perhaps it was just being in Ohio with weather extremes and road salt. And maybe a little bit of a technician doing bad things.
  4. Mar 27, 2023 at 4:01 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    @RichochetRabbit very smart decision to replace the bad lugs. The one piece will never give you the same issues the two piece would.
    joeyv141 likes this.
  5. Mar 27, 2023 at 4:16 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I was a mid level ford dealer tech for 5 years recently and watched over the quick lube guys, I hate 2 piece lug nuts and it doesn't matter about being in the rust belt or the wrong socket size, I am in New Orleans and a few times have seen them get swollen after only 4 or 5 rotations. I replaced my Tacoma lug nuts years ago with one piece lug nuts I bought off Ebay, Dorman also makes good one piece lug nuts.
  6. Mar 27, 2023 at 4:23 PM
    Squirt
    Squirt Certified in forklifts and meme stealing =)
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back. J&L catch can
    I've been needing to get them for my F150. Do you know if gorilla lug nuts are good?
  7. Mar 27, 2023 at 4:38 PM
    joeyv141
    New Jersey
    I have never seen any issues with gorilla locking lug nuts, in the back of my head I have worried about how thin the metal for the lug nut key is, always seems like if a lug nut is too tight the key might break, never seen it happen though. I should mention they are very easy to remove with just a normal socket, much easier then other locking lug nuts.
    Squirt[QUOTED] likes this.
  8. Mar 27, 2023 at 4:39 PM
    Squirt
    Ben
    Awesome!! Thank you!
  9. Mar 28, 2023 at 8:58 AM
    Discount Tire
    Arizona, USA
    @Squirt most locations carry West Coast install kits and can get you taken care of by installing them for you.
    Squirt likes this.
  10. Mar 28, 2023 at 8:59 AM
    Squirt
    Ben
    Sweet! I'll have stop by sometime.
    Discount Tire[QUOTED] likes this.
