Two questions about my '02 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacodumbass, Mar 6, 2012.
  1. Mar 6, 2012 at 2:03 PM
    tacodumbass
    tacodumbass [OP] 2007 tacoma 4x4
    Boston
    '02 Tacoma 2WD
    Hi all,
    Just got a 5 lug 2WD '02 Tacoma, and after a while the engine light went on and I got it diagnosed at AAP and the reading was:
    "P0136, 02 sensor circuit bank 1 sensor 2, see P2270, P2271"
    I'm sure there's been plenty of threads devoted to the 02 sensor, but wouldn't mind having this cleared up, a little bit. P2270/1 seems to refer to" intermittent idling fluctuation and acceleration hesitation Symptoms prior to CEL."
    The second question is the O/D OFF light- every time I start to drive, the light is always off (meaning the O/D is on). I'm not always on the highway and so I'd like to keep it off (so the O/D light would be on). But every time I drive and then turn the O/D off (O/D OFF light comes on), and then shut down the engine, and the next time I drive, the O/D light is off, meaning it's back in O/D?? What's going on? Is this a default feature?
    Any thoughts?
    Thanks in advance..
  2. Mar 6, 2012 at 2:14 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Can't say on the code readings, but the O/D is always set to on (Light is off) when you turn the truck off. Unless you are towing around town, I see no point in having it off in the city, other than to reduce transmission shifting/heat.
  3. Mar 6, 2012 at 2:19 PM
    tacodumbass
    Boston
    '02 Tacoma 2WD
    Thanks for clearing up the 2nd question.
