Two year free maintenance
Discussion in '3rd Gen. Tacomas (2016-2023)' started by payanja, May 28, 2021.
  1. May 28, 2021 at 3:17 PM
    payanja
    payanja [OP] Active Member
    My taco hit its first 5000 miles today. Should I take advantage of the free maintenance or should I just do it myself? Is it worth taking it in?
  2. May 28, 2021 at 3:20 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    I wouldn't because I'd have to wait 2 hours for them to rotate the tires and top off washer fluids. Not worth the time.
    Plus I have OCD that I need to know each of the lug nuts is torque to spec otherwise I'd lose sleep
  3. May 28, 2021 at 3:21 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    This has been discussed 1000 times in here . Some do most say they don't i did .
    MadKatt, GillyLink and Chew like this.
  4. May 28, 2021 at 3:23 PM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Just me.......
    Mine has 20k. She has never touched the dealer since I bought her. I got recall letter for the fuel pump. Since I do not have any symptoms I won’t take her there.
    I know I have serious trust issues.. so for now, no dealer visits.
  5. May 28, 2021 at 3:24 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    If you have the time, I'd say let them do the first one. Just an inspection and tire rotation.
    Side Note: I've had a really good experience buying Oil and filters from the Parts Department. At least you still have some type of record sowing that you purchased the stuff. And their products aren't that bad priced.
    Hook78 and payanja[QUOTED][OP] like this.
  6. May 28, 2021 at 3:26 PM
    KBOX
    KBOX In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    Or a wheel.
    Hook78, RustyGreen and usmc2msu like this.
  7. May 28, 2021 at 3:26 PM
    Couesfanatic
    Couesfanatic Well-Known Member
    I let them do it. Just check after and make sure they didn't mess anything up. If they did, they fix on their dime. My free maintenance is up and now what...
    TnShooter likes this.
  8. May 28, 2021 at 3:29 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    My own personal opinion, if you are physically able to do your own maintenance you should. Then you will know everything is done correctly. WAY too many horror stories of dealerships over tightening and under tightening and not doing the work they said they did. I would be very happy for my tundra to never go to the dealership even once.
    payanja[QUOTED][OP] likes this.
  9. May 28, 2021 at 3:30 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I understand that man.
    I really do have OCD, and neither way is good for me.
    If I do it myself, I question everything I did.
    I check and recheck. Takes my 3 times longer to do a simple job.
    If I pay someone else, I worry they might not have done it right.
    OP, I would let the dealership do the work.
    If it breaks, they fix it.
    If you break it, you fix it. And pay the bill.
  10. May 28, 2021 at 3:45 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    It’s free and u have documentation that the service was done in case any issues should arise . It’s not just tire rotation and top of wiper fluids . They check driveshaft and parts visually . Grease the zerks if you do off roading . But you need to let the dealer know that since they won’t perform that part unless specified by the customer they off road .
  11. May 28, 2021 at 3:55 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I purchased a pre-certified and got free maintenance for 2 years. I want them to be on the hook if something happens. If you do it yourself. You may be unable to prove you did the maintenance and did it correctly. They checked the frame and will rustproof it for free. I even got the service records from day 1 through the dealer. Mitigate the risk!
    Afilao and payanja[OP] like this.
  12. May 28, 2021 at 4:20 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    are you going to shake a stick at getting your floor mats inspected. 2 free oil changes, overtightening of filter housing and lug nuts?
  13. May 28, 2021 at 4:34 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I just finished my last one at 30. I'll be doing my own from now on, but I certainly had no issues at the dealer.
  14. May 28, 2021 at 4:50 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    My dealer was cool enough just to hand me the 7 qts of oil and the filter once a year. I bought enough parts for my 1st gen that they must have figured i knew what i was doing. They still ran it thru the service dept and got the miles off the truck so it was on record as my two free oil changes and one cabin filter.
  15. May 28, 2021 at 5:10 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    My '96 has 415,000 trouble-free miles on it and has never been back to the dealer since I drove it off their lot 25 years ago this month.
    If I had been taking it back for their maintenance I'm sure it would be in junk yard by now.
  16. May 28, 2021 at 5:17 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Don't forget, they lube the propellor. I remember reading that after I got the 15,000 "free" service. I had to google that. I bought this truck with about 12,500 miles on it. I was surprised, since I bought it from a Ford dealer, that Toyota still honored the free 20,000 mile service deal.
  17. May 28, 2021 at 5:17 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I took mine to Hanover Toyota, one of the dealerships that has a good reputation for my 5000 mile service and I can't say a word bad about them. I made an early Saturday morning appointment so there were few people ahead of me. I was in and out in like 45 minutes.
    I don't think I will visit the dealership for everything. I can do my own oil changes and many other routine things. I have a good independent mechanic too. Still those service are in a way included in the price of your truck. That and you want to start a service history so I say go get the work done you paid for it.
    If you want to track you own work now or later the Toyota app allows you to enter diy maintenance and other shops work or you can also use Carfax
    Hoofhearted49 likes this.
  18. May 28, 2021 at 5:23 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Nothing is free you’re actually paid for it when you bought the truck so Why wouldn’t use it?
    SandyTaco4x4, Hoofhearted49 and Chako like this.
  19. May 28, 2021 at 5:37 PM
    CaptainBart45
    Bart
    Work in progress...
    In my case, the free maintenance was actually free. Ford dealer nor I even knew about it.
  20. May 28, 2021 at 5:40 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    its a good OCD to have. I came back home after a rotation missing 2 lug nuts
