tx pro baja lift vibe?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dobri56, Jun 2, 2012.
Thread Status:
Not open for further replies.
  1. Jun 2, 2012 at 10:37 AM
    Dobri56
    Dobri56 [OP] Well-Known Member
    Dan
    Massachusetts
    2012 trd sport longbed
    Smitty Bull bar, PIAA 540, MBRP turn down exhaust, Tractor trailer tool box. Black headlight mod, fog light mod, TRD seat covers, tacoma floor mats, Recon under tailgate light
    So I was wondering because toyota did its own lift with the baja edition are those trucks having any issue with vibrations at all. I'm lifting my 2012 trd dclb on monday and If i get a vibe just getting the front diff bearing but was just curious just seemed a little odd unless they changed the front diff around?
  2. Jun 2, 2012 at 10:37 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    dude.....its like a 1 inch lift...
  3. Jun 2, 2012 at 2:21 PM
    TEricksen
    TEricksen Well-Known Member
    Bilstein 50/60mm custom valved silver shocks, different springs front and rear, longer brake lines, and I am told there is a bit of engineering put into the package that actually works very well with no vibration...... but I do value your opinion.
  4. Jun 2, 2012 at 5:48 PM
    TEricksen
    You are incorrect in your assumption.... but again, you are entitled to your opinion.
  5. Jun 2, 2012 at 5:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I just read in Popular Mechanics, that the TX Pro Baja has 9.25" front travel in the suspension, and 1.75" lift over the stock trucks....
  6. Jun 2, 2012 at 5:56 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    You're such a big meanie face Christian. :D
  7. Jun 2, 2012 at 5:56 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    Those "5100's" are alot beefier than my 5100's
    And the rear 5160's will have a higher oil capacity than the 5150
    Edit: the coilovers pictured have a 60mm piston diameter while the 5100's have a 46mm piston. 30% larger than the 5100's
    and the shaft diameter is 18mm, compared to the 14mm 5100's.
  8. Jun 2, 2012 at 5:58 PM
    TEricksen
    The shock valving is completely different from any off the shelf Bilstein shock.
    The brake lines are longer.
    The springs are different.
    Toyota spent a huge investment in engineering the suspension to work.
    You are somewhat ignorant.... but still entitled to your opinion.
  9. Jun 2, 2012 at 6:00 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    OP, how much lift are you adding to your truck.
  10. Jun 2, 2012 at 6:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    PM said the retail price was 35,499.00 But, Im sure it is to some folks.
  11. Jun 2, 2012 at 6:46 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    Often wrong, never in doubt....
    David
  12. Jun 2, 2012 at 6:52 PM
    YumaTRD
    David
    El Cajon, CA
    Solid Axle Yota
    he is probably adding Cali tax and the interest paid over the loan :confused:
    The baja package is a better setup than my 5100's, I wouldn't mind getting me a set of the front coilovers for my rig
  13. Jun 2, 2012 at 6:52 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Why would anyone waste their money on that package when you could build your own cheaper WITHOUT the monterous gay sticker ?
  14. Jun 2, 2012 at 6:56 PM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Part of an email I got from a TRD Product Development Manager;
    "... we don't currently have plans to sell the Baja Series parts as standalone accessories, at the request of our Truck Marketing group. I can tell you that the shocks are not off the shelf parts from Bilstein, they have unique extended and compressed lengths as well as different bushings and valving, all of which are the result of significant development work.
    The spring is also a custom part number for TRD, but you could buy a similar spring from Eibach, as I recall the rate is around 625 Lbs/In.
    We also use a different rear leaf spring (3+1 pack), a unique brake line spacer, line clamps, bump stops, and some other hardware such as frame mounted reservoir clamps."
    And from a Bilstein racing rep;
    "... We will probably release our own aftermarket tune anyway which would be better than the trd tune anyway."
    Frank
  15. Jun 2, 2012 at 6:57 PM
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    only if you make assumptions and use no factual data to form your opinion.
  16. Jun 2, 2012 at 6:58 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    TX Baja has a 2" lift. Toyota probably kept it conservative to avoid changing UCAs or getting vibes.
    Is it worth it? I spent less than $2000 on Icons front and rear that will outperform the 2.4" Bilsteins.
  17. Jun 2, 2012 at 7:00 PM
    Canazes9
    David
    Texas
    Many people don't like to wrench on their vehicles.
    Many people don't want to alter a vehicle from how it was delivered.
    Many people find they can negotiate pricing on new vehicles at a dealership - usually the more options it comes with the more room for negotiation there is. Maybe not the first day these hit the showroom floors, but soon....
    Beauty is in the eye of the beholder - some of the pictures I've seen in black looked pretty good with those graphics.
    David
  18. Jun 2, 2012 at 7:00 PM
    TEricksen
    I'm guessing you hear that word frequently.
    This issue has nothing to do with "agree" or disagree. There are simple facts that you seem to intentionally ignore; for what end I do not understand.... it's either that, or you honestly don't understand..... hence the term, "ignorant". "Ignorant" is a positive word that gives an honest benefit of the doubt, because the other possibility.......
  19. Jun 2, 2012 at 7:01 PM
    Blueberry
    Blueberry Well-Known Member
    Nick
    Newton, KS
    T/X Pro named Blueberry by my daughter
    Custom Roofrack, Satoshi, Ammo-can in bed, Hi-lift, 2 HID Hella 700's, 4 Automatcentral 7" Offroad Lamps, 2 Hella Work/Bed Lamps, "Derp'd" Radio and Shifter Console, Anytime Fog-light mod, Anytime Rearview Camera mod, DTRL mod, Awesome TW sticker mod.
    $36,215 for an access cab. I'll pass..
  20. Jun 2, 2012 at 7:02 PM
    OZ-T
    Peter North
    British Columbia
    Huh
Thread Status:
