TYetti's 2.7L Rebuild/FULL SEND/EAF build
Discussion in '2nd Gen. Builds (2005-2015)' started by TYetti, Mar 13, 2014.
  1. Oct 30, 2018 at 8:12 PM
    #681
    TYetti
    TYetti [OP] 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    So the desicion has been made.
    I've spent almost the last week deciding what to do with the now disabled Tacoma. I seriously considered a 2uz simply based on local availability as well as the 3uz because I live on the west coast and there are an abundance of JDM importers around. I even looked at the 2jzgte. I quickly eliminated the 2jz as it's high strung nature won't work with wheeling and the way I used my truck. The uz is the best option for replacement with its abundance of low end torque. It also has the ability to bolt up to my r155f with the use of an adapter, I've got the price to around 5500-6500$ I'm sure more things will pop up moving the price up further.
    Still following ok... I went and talked with local 4x4 shop owner and general all knowing Toyota guy for an opinion on the situation. He showed me the final tally on a few V8 builds he's done over the years. Let's just say it gets expensive no matter how much you pre plan. He sent me over to the local machine shop he uses for engines and after talking with the owner who's also seen a few 2trfe's with the same issue. He says he's able to reman the engine for 4500 at the very top end using Toyota seals etc, also he's rebuilt some as long as 5 years ago and has not had one return with the ring issues. I also found an engine at a wrecker about 4 hrs away, they claim it has 40k km on it but haven't been able to prove it to me, although it is the cheapest option at 2500 it's far too risky imo, no guarantees or warranty and having to deliver my engine as a core could leave me with an engine that's shit and still needs a rebuild. I'll be proceeding with the rebuild in the near future. It's just the option with the least amount of questions.
    tacoma16 likes this.
  2. Oct 30, 2018 at 8:36 PM
    #682
    bigfella13
    bigfella13 Well-Known Member
    Nick
    Colorado
    4 banger 4x4
    Lift, armor and such. Money pit, check out the build thread...
    Stay with me here.... you need 8 cylinders.....
    Dual 2TRFE’s, both supercharged a la hot wheels twin mills 1969. You stay true to the 4 banger heritage, with wicked low end torque!!!
    We can do this. We have the technology!!!
  3. Oct 31, 2018 at 6:27 AM
    #683
    TYetti
    Mat
    Lol if only it were that simple FML what a screw around
  4. Oct 31, 2018 at 6:53 AM
    #684
    bigfella13
    Nick
    Colorado
    4 banger 4x4
    Ha! A few cases of beer and a welder and we could figure it out!
  5. Oct 31, 2018 at 7:11 AM
    #685
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    Noticed this summer my truck is taking oil too. Saw it first at an oil change, that there wasn't 6L of oil in the oil pan. Then I started to gauge the oil more often. Truck takes around a quart in 3000km. no leaks, no blue smoke. I changed the spark plugs an noticed one was more dirty than the others, so I guess it is a ring thing too. I also changed the oil to Castrol. Castrol smells "bad" compared to others, and I started to smell it, so I know it is burning and not going in coolant. It's a sad thing... I am trying seafoam to see if it can get the truck back on track. could just be a dirty ring that is sticked to the piston. I hope so...
    Edit: I have 267 000 km on the clock
  6. Oct 31, 2018 at 7:52 AM
    #686
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Great information!
  7. Oct 31, 2018 at 12:04 PM
    #687
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    My brothers truck is an 09 with a 2.7. He’s been saying that it has been using quite a bit of oil lately. Now you guys have me wondering...
  8. Oct 31, 2018 at 2:21 PM
    #688
    TYetti
    Mat
    A few cases of beer and a welder and I might have a Cummins Tacoma lol
    Mine started around 250k km I estimate it's escalated from 1L every 8k km to 1L every 1000-1500 I'd be worried. I predict that many 2trfe will fall victim to this ring issue and prematurely kill off an otherwise good engine. Personally I would get it scoped asap if your pistons are covered in more gunk than carbon you likely have the issue. You may be able to just re ring and replace the pistons but that will depend on what the cylinder walls look like
    I try to add some tech into the photos
    I'd be concerned
    tacoma16[QUOTED] likes this.
  9. Oct 31, 2018 at 2:31 PM
    #689
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Yeah why don't you do the Cummins conversion rather than spending all that dough to have an extremely underwhelming engine?
    Given how you use your truck ditching spark plug wires would be the ticket for sure!
    And much more TW credit!!
    Kemosabe likes this.
  10. Oct 31, 2018 at 2:35 PM
    #690
    TYetti
    Mat
    2tre is distributorless anyways so it technically doesn't have spark plug wires it has coil packs. However this has come up a few times. The Cummins swap series is literally the shittiest engine they make. It comes from a line of small diesels mainly used in busses and small equipment in asia. They also have massive overheating issues and are just generally shit not like the 12v that earned the reputation. Also a 4bt although reasonably priced locally would overwhelm the ifs and make the truck so God awfully front heavy it would actually suck to wheel. Probably looking at minimum 10k to get that engine in and running with the trucks electronics and then another 20-25k for SAS because if you're gonna 4bt all the things you need wontons
    tacoma16 and Kemosabe like this.
  11. Oct 31, 2018 at 3:55 PM
    #691
    TireFire
    Olympic Peninsula
    Yeah well I wasn't necessarily talking about the Cummins crate engine.
    What about the hilux diesel? At least that's Toyota, proven and will not be a fitting nightmare and the chassis are similar
  12. Oct 31, 2018 at 5:02 PM
    #692
    Kemosabe
    Louis
    Yeah i'll have to have it cheked. I just parked it now since I have a new DD from work. I'll be good to take care of the truck. I hope I got it in time... if not, trade in it will be:( i was already thinking about it for the future family (not yet in progress but still) that oil problem may just push things faster
  13. Oct 31, 2018 at 5:44 PM
    #693
    TYetti
    Mat
    Ya I looked at the d4d engines only 15k to get one here then do the install and try to make the diesel talk with the taco electronics, oh and replace the whole fuel system
  14. Oct 31, 2018 at 6:27 PM
    #694
    TireFire
    Olympic Peninsula
    $15k?? :eek:
    Fuck that! No way!I'm sure you can get that cheaper unless you're talking about a brand new motor.
    Your trans is already manual and the matching of the body electrical to the ECM is part of every engine transplant.
    Shouldn't be that bad though since they're both Yotas and the Hilux is the Taco's twin
  15. Oct 31, 2018 at 6:45 PM
    #695
    TYetti
    Mat
    I'm too deep gotta keep on sending it
  16. Oct 31, 2018 at 6:48 PM
    #696
    TYetti
    Mat
    Common misconception the Hilux has more in common with the 4runner than taco. True but shipping one from Australia or NZ is insane, there's a reason diesel toys charges so much, then there's duty and taxes import fees, customs fees, figuring out radiators,AC getting a trans adapter made, clutches etc etc etc etc.. trust me I only work 4 10s I have a lot of time to read and research.
    Kemosabe and TireFire[QUOTED] like this.
  17. Oct 31, 2018 at 6:55 PM
    #697
    TYetti
    Mat
    I wish it wasn't the case, but sticking with the devil I know is going to be the best option. It unfortunately messes with my suspension and driveline plans
  18. Oct 31, 2018 at 7:37 PM
    #698
    Kemosabe
    Louis
    Yep in your case you have to continue. Maybe you can get lucky and find another 2.7 to swap in this winter... hope the best tho! I dont want to see the end of this truck
    Kuntrykid likes this.
  19. Oct 31, 2018 at 8:04 PM
    #699
    TYetti
    Mat
    I'm rebuilding I've found Multiple 2.7s even the dual vvti 2015 but none of the wreckers can physically verify how many kms are actually on the engines or let me see them running so fuck em.. most are cheaper than rebuilding but without verification they might as well have a million km on them cause who really knows
  20. Nov 1, 2018 at 4:56 AM
    #700
    TacoNorth76
    TacoNorth76 Well-Known Member
    Dave
    Maine
    2015 4cy Auto 4x4
    Sorry to hear of this trouble, have really admired your build. Any preventative measures for this?
