TYetti's 2.7L Rebuild/FULL SEND/EAF build
Discussion in '2nd Gen. Builds (2005-2015)' started by TYetti, Mar 13, 2014.
  1. Nov 1, 2018 at 7:40 AM
    #701
    TYetti
    TYetti [OP] 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Thanks man. I doubt it, it's definitely a factory assembly issue, much like the 2AZ? I think it was in the small cars in the mid 2000's. Monitor it and if you get it report it to Toyota corporate in the hopes that if enough people report it they'll issue either a tsb or a recall.
  2. Nov 1, 2018 at 5:56 PM
    #702
    TYetti
    Mat
    This post actually got me thinking about 3rd gens today, I did a bit of searching and found about 90% of my mods would bolt onto a 3rd gen, I'd just have to swap over stock stuff onto mine and then sell or trade in. I decided I'm not that big of a douche, since getting the new valve cover back on the truck really struggles to run, I was barely to make it around my block, I'd hate to pass that on to someone else who just wanted a taco and thought they were getting a deal. Basically the truck is going into storage now, I've gotta do ujoints on my 86, now too.. I'm gonna start to disassemble the taco make it less appealing to potential thieves. You know remove tent, vhf radio etc stuff that people would try and quickly take. I'll be starting to slowly take everything apart and prep the engine for removal as well, so it can be dropped off at the engine builder. Also going to start assembling parts for when the new engine comes back to me most likely in the new year. Gonna slap a header and new exhaust on there since the cat is most likely plugged full of oil. Also gonna replace the clutch while it's all apart and whatever other goodies I can sneak into this when my fiance isn't looking lol
  3. Nov 2, 2018 at 6:42 AM
    #703
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    I agree that passing it to someone else would not be nice, but by trading it in the dealer becomes responsible and will need to repair or get rid of it...
    Do you still have that Volks for DD?
  4. Nov 2, 2018 at 8:45 PM
    #704
    TYetti
    Mat
    If you look back on the other pages you'll see I now have an 86 2wd Toyota diesel pickup
  5. Nov 2, 2018 at 8:52 PM
    #705
    TYetti
    Mat
    So I scanned the taco with an obd2 scanner and it says it's the cam position sensor, I'm gonna double check everything is plugged in right when I get home from work tmrw, but if it is I'll add this to the growing list of parts that need to be replaced.
    So I'm adding things to the build list
    New air box cause mine is letting dust in it seems the top of the filter box is dusty on the intake side of the filter
    Magnaflow turn down cat back
    Lce header
    Hurst short shifter (which is longer shaft than OEM and angled different so my coffee won't get trapped when I'm in second or 4th)
    Aisin clutch and urd tob
    Fuck it might as well spend while I'm spending
  6. Nov 3, 2018 at 8:04 AM
    #706
    Kemosabe
    Louis
    Yep saw that, i also liked it lol was just wondering if you still had the volks, and the '86
    :spending:
    Lce headers and Hurst shifter are going to make a really nice difference!
    BassAckwards likes this.
  7. Nov 3, 2018 at 7:46 PM
    #707
    TYetti
    Mat
    Well see I don't wanna loose bottom end.. but I can always add more gears to make up for it
    tacoma16 and Kemosabe[QUOTED] like this.
  8. Nov 4, 2018 at 8:28 PM
    #708
    TYetti
    Mat
    I solved my check engine light issue. The cam pos sensor wasn't plugged all the way in. Intermittent signal caused the cell, I cleared the code with my scanner, gonna take the truck to work tmrw to see how it runs, I'll be data logging the trip just cause I can. My 86 threw a ujoint so I ordered some greasable Spicer joints should have them by wednesday, really sucks that I have to order stuff online to get a decent price, 77$ for all 3 joints with shipping, local parts store wanted 30$ a joint for Moog garbage
  9. Nov 5, 2018 at 11:15 AM
    #709
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    curious what site...My site only has moog and another off brand...
  10. Nov 5, 2018 at 11:52 AM
    #710
    TYetti
    Mat
    Rock auto... Holmes they may not have them available for new taco. My taco Spicer's I ordered off Amazon for 15$ ea same with center bearing Spicer brand was like 40$
    Nimble9 and tacoma16[QUOTED] like this.
  11. Nov 5, 2018 at 2:36 PM
    #711
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Awesome. I’ll check Amazon!
    TYetti[QUOTED][OP] likes this.
  12. Nov 7, 2018 at 12:23 PM
    #712
    TYetti
    Mat
    Ordered up a dual pillar pod and some auto meter gauges. I did the dual pod cause it looks cooler than a single, gonna shove a oil pressure gauge in there and an Afr guage cause it looks cool
  13. Nov 7, 2018 at 12:26 PM
    #713
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    What engine oil are you running?
  14. Nov 7, 2018 at 12:29 PM
    #714
    TYetti
    Mat
    Mobil 1 5/20 or 30 whatever the spec is, too cold here for the 0/20, I see they make Rotella now for gassers so I'll probably do that with the new engine
  15. Nov 7, 2018 at 12:30 PM
    #715
    TireFire
    Olympic Peninsula
    While you're still on this one try using heavier oil and see if that slows down the consumption
  16. Nov 7, 2018 at 12:47 PM
    #716
    TYetti
    Mat
    I've been driving it actually since my 86 need ujoints it's been doing ok.. I'll continue to monitor it as is.. the rebuild is happening either way so slowing down the consumption is meh at this point
  17. Nov 29, 2018 at 5:36 AM
    #717
    TYetti
    Mat
    So the other day I took my tent and awning off the truck, and put them into storage for the winter or until the truck is running properly again. The cat is now pretty much fully plugged. She just drinks fuel, and runs like shit.
    On the bright side I ordered an lCE Header and pillar gauge pod for the oil pressure and other gauge I decide to put in there most likely AFR
  18. Nov 29, 2018 at 5:47 AM
    #718
    TacoNorth76
    TacoNorth76 Well-Known Member
    Dave
    Maine
    2015 4cy Auto 4x4
    Do you have a link to the pod and gauge you will be using?
  19. Nov 29, 2018 at 6:04 PM
    #719
    TYetti
    Mat
    Kuntrykid likes this.
  20. Nov 30, 2018 at 5:41 AM
    #720
    TacoNorth76
    Dave
    Maine
    2015 4cy Auto 4x4
    Thanks!
    I have looked and can't seem to find one of these for a 2015. Have read where with a little trimming this one will work. So might give it a try.
    TYetti[OP] likes this.
