Tyger Tonneau Cover from Amazon
Discussion in 'Tonneau Covers, Caps and Shells' started by tbrackman84, Jan 2, 2020.
  1. Feb 3, 2020 at 5:38 PM
    23psi4age
    23psi4age Member
    G
    South Florida
    2020 Quicksand SR5
    I just put the Tyger Tri Fold on my 2020 and I like it a lot.
    dclbYak likes this.
  2. Feb 4, 2020 at 1:57 AM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    Looks good. Mine held up great on a cross country move with no leaking.
  3. Mar 5, 2020 at 1:29 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    Tyger tri fold from Amazon, $200. Went on easy. Not real confident with safety strap. Put in on this past weekend, no rain yet.
  4. Mar 5, 2020 at 1:32 PM
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    What’s the safety strap for?
  5. Mar 5, 2020 at 1:42 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    I guess if you’re driving with it folded up and the front latches give out the safety straps will hang onto the top until you pull over and fix it. You’ll know by the loud banging and other cars honking.
    Th3Outl@w and theredofshaw like this.
  6. Mar 10, 2020 at 5:49 AM
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    I'm on the fence in buying one of these either the roll up or tri fold. Do they flap and flutter a lot on the highway?
  7. Mar 10, 2020 at 6:09 AM
    theredofshaw
    very slight flutter of the vinyl on the tri-fold but not enough to be distracting to me (but who's actually looking in their rearview ;) )
  8. Mar 10, 2020 at 8:01 AM
    skierd
    David
    Fairbanks, AK
    It flutters but it doesn’t make noise noticeable in the Cabin.
  9. Mar 10, 2020 at 1:31 PM
    mattehww
    mattehww Well-Known Member
    Minneapolis, MN
    2018 SR5 Access Cab 4x4
    Very minor fluttering, not distracting for me. And I'm not sure on the trifold, but the roll up has some adjustment at the end so you can pull /loosen the latch as needed to get out slack. I'll typically adjust it once or twice a year as temps change (but I'm in the Midwest with cold winter)
  10. Mar 10, 2020 at 3:44 PM
    skierd
    David
    Fairbanks, AK
    Interesting, I remember reading that but I’ve never adjusted mine... never tried to roll it up at -40F either but still.
  11. Mar 11, 2020 at 5:51 PM
    mattehww
    Minneapolis, MN
    It's not a big deal, I only noticed when the touchless car washes started to force some water in the back in the winter which didn't happen in the summer. I'm guessing the material shrank slightly and kind of "pulled back" or lifted the end slightly. Loosened it up a bit and it seats properly again.
  12. Mar 19, 2020 at 12:15 PM
    Inverno4
    Baltimore, MD
    2020 DC Off-Road MT
    The roll-up one for a 2020, 5' bed is now out of stock on Amazon and has been for awhile. I wonder if there will be more.
  13. Mar 20, 2020 at 5:59 AM
    mattehww
    Minneapolis, MN
    Chinese product (just like everything else) so maybe in a few months (hopefully) when things slow down and supply chains pick back up. Who knows when it may actually be though.
  14. Mar 23, 2020 at 3:51 PM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    For those on the fence, I have the Tyger rollup and while you can see it fluttering in the rear view mirror, you can't hear or feel it in the cab. And for those that want to carry bikes (or really anything in the bed with the Tyger rolled up), with a 5' bed the "roll" that is left is about the same diameter as the width of the front bed rail plus the gap between the bed and cab, so it basically exposes the entire bed opening with no rear view impact. In other words, effectively a completely open bed. To me that was the real value ... a tri-fold may look better, but takes away the usefulness of a pickup. At least 2 years old now, always parked outside, holding up great.
    dleriche likes this.
  15. Mar 28, 2020 at 2:08 PM
    #35
    ChouDawg
    ChouDawg Well-Known Member
    San Diego
    2020 Super White TRD OR
    Have a MaxMate (Tyger) trifold from Amazon as well. The threads on the plastic latches aren't the most confidence inspiring and the rail inserts flex a little when tightened down since they're not machined to be a tight fit. So far no major leaks with zero added weather stripping, even with the 'major' rain we've been having recently in SoCal. Definitely worth every penny :thumbsup:
  16. Apr 26, 2020 at 5:19 AM
    #36
    Jotorobi
    Jotorobi Active Member
    West Virginia
    2008 4x4 V6 Access cab SR5
    do you have any issues with it leaking?
  17. Apr 26, 2020 at 8:03 PM
    #37
    dman100
    2016 TRD OR DCSB
    Long story, but in a nutshell, when I used to have an ARE cap on my 3rd gen, it didn’t leak more than a few dribbles down the front, in torrential storms. I removed the cap for a while, and when I reinstalled it I used triple bulb seal instead of the flat foam tape that had been on there before, thinking it would hold up better and could be reused if I removed and reinstalled the cap again. I also used a little butyl tape to seal up some gaps. After that it leaked worse; not enough to be a real problem but annoying! Then I sold the cap, and installed the Tyger. Now it leaks exactly the same as it did with the cap, at the front right corner, so I don’t think it’s the Tyger leaking. Certainly no visible leaks through the Tyger material itself, or its seams or side Velcro.
    Jotorobi[QUOTED] likes this.
  18. Apr 27, 2020 at 9:27 AM
    #38
    mattehww
    Minneapolis, MN
    I get no leaks anywhere from the cover itself. The only place you'll get some water coming in is from the front bed rail and some along the tailgate sides. This is pretty unavoidable with any type of cover or tonneau due to the bed design but can be sealed up if desired.
    You're not going to get the 100% protection like you would an SUV.
  19. Apr 28, 2020 at 10:44 AM
    #39
    Jotorobi
    West Virginia
    thanks for the feedback. I am likely going to take off a camper too and go to the tonneau cover.
