Type of Detroit locker
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tomass321, Jan 5, 2016.
  1. Jan 11, 2016 at 9:40 AM
    Tomass321
    Tomass321 [OP] Well-Known Member
    Thomas
    San Luis Obispo
    2014 Base Tacoma access cab. 1994 Toyota pickup long travel
    What size are they?
  2. Jan 11, 2016 at 2:19 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Nitto Terra G2 265/70/17 which I guess is a 31" tire? Not much bigger than stock but I'm planning on going bigger. Maybe 33"?
  3. Jan 11, 2016 at 2:24 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    with the 265/70R17 no need to re-gear. Also note that if you do re-gear you gotta do front and rear diff $$$$ even on 33's the stock gearing works decent.... and maybe if you are lucky you can find a 4cylinder 4x4 truck that has re-geared and grab his 4.10 gearing for cheap as they will bolt right up to your sport's diffs and be perfect for 33's compared to the stock 3.73 gearing.
    Tomass321[OP] likes this.
  4. Jan 11, 2016 at 2:30 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Good to know.
    This is one of those "duh" moments that I clearly didn't think enough about. Can't believe I didn't think about that.
    Also good to know. I'm hoping URD headers will help with a bit of the low end torque deficit too. I guess I'll wait and see how it unfolds.
  5. Jan 11, 2016 at 2:54 PM
    Tomass321
    Thomas
    San Luis Obispo
    I have decided on 4.56 gears in the rear and a detriot truetrac :) install is this thursday
    ItalynStylion likes this.
  6. Jan 11, 2016 at 3:25 PM
    Pigpen
    Dan
    Northwest Montana
    What size tires? With 33s I'm probably doing 4.10, but 4.56 is still on the table. The only reason I would consider stock gear ratio is to do one end at a time.
    Gotta lock it to drive in any snow deeper than this (unless it's really light snow)
  7. Jan 11, 2016 at 3:35 PM
    Tomass321
    Thomas
    San Luis Obispo
    Im running 32's right now but moving to 33's. And i totally feel it. I live in tahoe over the summer so its more of my exploring and shuttling truck! And what lockers do you have in yours? I know truetrac does good on ice and snow to my understanding
  8. Jan 11, 2016 at 5:22 PM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    That is what I run - I'm on 33s.
    Great setup, and I tow.
  9. Jan 11, 2016 at 5:23 PM
    Tomass321
    Thomas
    San Luis Obispo
    Okay good!! Im glad to hear that! Is there a noticeable difference in power after the regear?
  10. Jan 11, 2016 at 5:27 PM
    Scott B.
    Scott
    Georgia
    Not really. Remember, it's a Tacoma, not a built Mustang....
    However, it moves nicely, goes up a hill without bogging down. The throttle is nice and responsive.
  11. Jan 11, 2016 at 5:28 PM
    Tomass321
    Thomas
    San Luis Obispo
    Okay good thats what i wanted to hear! Moving from 215/65/15 to 265/75/16 (and soon 285/75/16) i definately need that. Thank you sir!
  12. Jan 11, 2016 at 5:33 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    I'm running 4.56, 32s, and a Detroit truetrac. Love this setup for a daily driver. If this was a weekend or trail rig, I would have gone lower gears, but 4.56s and 32s were made for each other on the road. The truetrac provides traction from two tires with minimal slip required even at low speeds. For my use it was well worth the money.
  13. Jan 11, 2016 at 6:24 PM
    Pigpen
    Dan
    Northwest Montana
    Wow, all this talk about 4.56 and 32 inch tires is surprising. I'm on 33s with stock gears and am very happy in daily driving. I feel I'm lacking power in towing and offroading. No lockers yet and haven't decided on 4.56 or 4.10, but going with ARB front and rear for certain.
    I currently get 18 mpg in summers for daily driving, 15 towing my 1958 camper. Winter is about 16 for daily driving. I'd like to regain some fuel economy, as well as some power.
  14. Jan 11, 2016 at 7:09 PM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Probably the difference between the 4 and the 6. I felt my truck was too high geared with factory tires with the relatively weak 4cyl. Going from 30.5 to 32 just made it that much worse. 4.56s and 32s are what it should have been from the factory.
  15. Jan 11, 2016 at 7:52 PM
    #35
    nd4spdbh
    SoCal
    yes you have to be concious of the difference between the I4 and V6 6 lug ratios..... V6 is 3.73 stock I4 is 4.10 .... so when an I4 says 4.56's for his tire combo... thats likely too high for us v6ers
  16. Jan 11, 2016 at 8:05 PM
    #36
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    I went with front and rear arb with 4.88's (4cyl). Contemplated about putting a Detroit in the rear and arb up front (I have no problem with the Detroit in the rear for a dd). But when it came time for me to order I said fuck it and went arb in both diffs. Only problem I've had so far is gear oil blowing out of the rear locker solenoid, still haven't fixed it yet, no time or money to have the diff opened.
  17. Jan 13, 2016 at 9:48 PM
    #37
    Tomass321
    Thomas
    San Luis Obispo
    Okay so everything is being installed tomorrow. My plan was to go out this weekend for three days in pismo. Is this a good idea or should i break in the gears for 100 miles or so first
  18. Jan 14, 2016 at 12:16 AM
    #38
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
  19. Apr 24, 2016 at 4:52 PM
    #39
    Flyota716
    Flyota716 Well-Known Member
    Derek
    03 white tacoma
    OK I have been looking into a locker but my ride is a daily driver and don't want the quirks of a locker or the expense of a selectable let me start with I live in fl no snow no rock climbing it is strictly sand and mud trails I will be running 32s with factory 4.30 gears do u think I will appreciate the trutrack or do I have to bit the bullet on a real locker?
  20. Apr 24, 2016 at 11:02 PM
    #40
    Tomass321
    Thomas
    San Luis Obispo
    You will honestly be fine with the trutrac
