Type of fluid in first gen Tacoma power steering
Discussion in '1st Gen. Tacomas (1995-2004)' started by NjayYT, Sep 17, 2021.
  1. Sep 17, 2021 at 5:31 PM
    NjayYT
    NjayYT [OP] Member
    Nathan
    1995 Green Toyota Tacoma
    None so far
    Hi everyone, so I’ve gone through hell getting my power steering figured out in my first gen Tacoma. I’ve put three new pumps in it one of them didn’t even work when I got it and the other two broke while I was driving. One of the new ones literally broke from steering too quickly. Yes you heard that right a turn I was taking came up on me quick so I turned faster than normal and the pump just stopped working. One of the pumps that broke was the OEM one that I rebuilt. I know the next thing that could break is the steering rack but I have a brand new OEM rack and pinion in it and I’ve been at this so long I know it’s the pump. My question that I hope someone out there can answer is if the stock rack and pinion can run generic power steering fluid or if it absolutely has to be Automatic transmission fluid that is in it. I am planning on buying Trail gears power steering upgrade kit or their pump and reservoir but it has to run normal power steering fluid. I don’t know what to do at this point if anyone has any suggestions on what to buy or what to do for the pump I’m all ears…
  2. Sep 17, 2021 at 7:36 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Power steering fluid or ATF meeting Dexron lll specs should be fine, Honda's, some Ford's, and vehicles with electrohydraulic power steering systems are the only ones I've ever seen that are picky about power steering fluid.
    Unfortunately the way things are with parts now that does not suprise me at all to get a run on defective parts, are you running stock suspension/tires or are you lifted/oversize?
  3. Sep 17, 2021 at 8:06 PM
    NjayYT
    NjayYT [OP] Member
    Nathan
    None so far
    I have a little bigger tires but that is it. I have completely stock suspension.
  4. Sep 17, 2021 at 8:16 PM
    Bishop84
    Bishop84 Well-Known Member
    I wonder if the rack is beat to hell and maybe steering joints worn, has the rack ever been replaced? Bushings?
  5. Sep 17, 2021 at 10:40 PM
    NjayYT
    NjayYT [OP] Member
    Nathan
    None so far
    Bishop84 I have a brand new steering rack in it and brand new lower ball joints. The bushings were also recently replaced!
  6. Sep 18, 2021 at 7:43 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    Technically you’re supposed to use ATF (automatic transmission fluid) if you go to the dealership, Napa or equivalent and ask them for the power steering aloud for your truck that’s what they’ll give you because that’s what Toyota calls for
    NjayYT[OP] likes this.
