Type of jack required to do AAL?
Discussion in 'Suspension' started by Fabulous, Apr 12, 2010.
  1. Apr 12, 2010 at 3:35 PM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2006 Tacoma double-cab TRD Sport
    Homertaco grill, Light Racing UCA's, 2.8" front lift (5100's at 0.85 setting and Eibach springs) 2" AAL with rear 5100's, Wet Okole seat covers fr/ bk. 17 x 9 Incubus Crusher wheels w/ 4.5" backspacing. 30% tinted front windows.
    So, I'm gonna do an AAL to my 06, and I need to know what type of jack to get...like how many tonnes, and how far up it must be able to reach to get it done. Any help is appreciated.
    Thanks.
  2. Apr 12, 2010 at 3:54 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The higher the better. Usually, when they're big tonnage - they lift higher.
    You might want atleast 4 jackstands also. 2 Large/Tall jank stands to lift the frame as high as you can get it. Then, you'll want the other 2 jackstands to hold the axle up while you work. Use the hydraulic jack as a lift and not to hold something up....
    Can't remember the tonnage....but I think ours is a CRaftsman 4ton.
  3. Apr 12, 2010 at 3:57 PM
    stenyeart
    stenyeart Well-Known Member
    Sean
    Lewiston, Idaho
    06 DC TRD OR SWB
    3" Toytec Lift w/ AAL, TRD CAI, Leer 700 Series, Hypertech Speedo Calibrator, Locker Anytime Mod, LR UCA's, OEM Roof Rack, Satoshi grill with Devil Horns Emblem, USA Spec PA-15 Toy Ipod Integration, Redline Tuning Hood Struts and EZ Down Tailgate.
    x2 on the using the jack for lifting and not holding.
  4. Apr 13, 2010 at 9:45 AM
    Fabulous
    Fabian
    Calgary, AB
    Thanks guys. I have the jack stands already, but wasn't sure how much lift I'll need. Truck is stock with 265/75-17's on it now, so I wan't make sure I get one that'll lift it up enough to get the wheels off the garage floor.
  5. Apr 13, 2010 at 9:45 AM
    Fabulous
    Fabian
    Calgary, AB
    ...what is the minimum lift from the jack I'll need do you think?
  6. Apr 13, 2010 at 11:45 AM
    Janster
    Jandy
    Lancaster, PA
    Getting the wheels off the ground isn't going to be enough. You need the wheels up MUCH higher than that.
    If you jack under the rear diff as high as you can get it - and you might have 6" under the tires (just guessing). Then put jackstands under the frame to hold the body up.
    You'll need to take the rear wheels off. Drop the axle down and put smaller jackstands under the axle.
    Installing an AAL can be tricky....because the arch and the sag of the current suspension, if you don't have the truck lifted up high enough, it's a royal PITA to get the AAL in there.
    Not sure what type of jack you'll need. We have a 3ton and the maximum travel on it is 20.5"
  7. Apr 13, 2010 at 11:49 AM
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    Here's what i used: :cool:
