Type of tape used for under hood insulation
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madjik_Man, Apr 27, 2012.
  1. Apr 27, 2012 at 11:32 AM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    So after research I realize that no one really has an solid idea as to why some trucks have the under hood insulation and fire retardant blanket and some don't. I also found out that there is confusion as to its overall function.
    Either way, I have it on my truck and part of the retardant mesh has been ripped and hanging down in my engine for almost 10 years now.
    I see that there is tape used (or possibly used by the previous owner of 1 year).
    What kind of tape is it? Obviously it has to be high heat resistant.
    Thanks.
    Is that flue tape? High heat duct tape?
  2. Apr 27, 2012 at 12:22 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Mine just had the yellow under the hood, just take it off unless you would like to keep it. Not sure what kind of tape is on there but flue tape would deff work i just ripped mine out though
  3. Apr 27, 2012 at 12:55 PM
    Madjik_Man
    That black mesh is supposedly fire retardant material.
    I'd like to keep it.
    Guess I'll just go with flue tape and hope it sticks
  4. Apr 27, 2012 at 1:22 PM
    bellassaiw10
    Currituck NC
    I figured the whole thing was fire retardant haha but mine started falling apart and i got tired of looking at it hopefully the flue tape will work out for you though
  5. Apr 27, 2012 at 7:00 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Any tape that is high temp tolerant will be fine. Honestly I would either dynamat the hood or tear that out. Kinda looks like a cheap chevy with that junk.
  6. Apr 27, 2012 at 7:03 PM
    Madjik_Man
    Good thing you only see it for the few moments my hood is up :eek:
    I'd rather spend $4 on a roll of tape than a couple hundred for dynomat.
    Just want that black mesh off my engine
  7. Apr 27, 2012 at 7:13 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I totally understand. I probably have more coats of wax on the underside of my hood than most people have on the whole truck. I've even clay barred it. :eek: I like everything looking clean even though I'm the only one looking at it.
  8. Apr 27, 2012 at 7:18 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    looks like the cheap imitation duct tape i bought from harbor freight.
