Type of timing belt - 97 taco 4 cyl
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KathyC, Jul 28, 2012.
  1. Jul 28, 2012 at 11:33 AM
    KathyC
    KathyC [OP] Member
    Frisco, Colorado
    97 Tacoma LX
    leaf springs on back, topper
    Hi there,
    Just got a 97 tacoma and wondering what kind of timing belt it has.
    My concern is whether it is one that breaks and you just fix it OR it is
    the kind that when it goes the whole engine gets totaled. (interference type?)
    Of course I plan to continue good maintenance on the vehicle but would like to have an awareness.
    Also---- the topper leaks. It was maintained in March 2012. When I drove it home yesterday through down-pouring rain it leaked. Is this a problem that is hard to fix? I have an appointment with place the orignal owner got the topper from to fix it Tues.
    Thanks!
  2. Jul 28, 2012 at 11:41 AM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Its got one of them chain/belts.
    I think you are good for 200K?
  3. Jul 28, 2012 at 11:54 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    If its 2.7 4 cyl then it should be chain. Nothing to worry until 200k miles unless you hear timing chain loose.
  4. Jul 28, 2012 at 3:11 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    i cant remember what 4-banger that is but i know its a chain. should be good for quite some time. it is extremely rare for them to break, most often the guides will wear and break, causing excessive slack and metal to metal contact between chain and cover. you'll hear it.
    i know nothing of your motor but on the old 22re's removing the valve cover and verifying that the guides were intact was a 20 min. job
  5. Jul 28, 2012 at 3:14 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    well on my 96 4 cyl, it was a chain.
  6. Jul 28, 2012 at 3:16 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    one thing i see is. '97 in 2nd gen sub forum? also if you are talking about a ’97 idk if it has a chain. i know the 2nd gen ’05+ have them. or at least the 4.0 V6 does.
