Type of winch? Load capacity?
Discussion in 'Off-Roading & Trails' started by MHS2846bg8, Feb 12, 2011.
  1. Feb 12, 2011 at 10:00 AM
    MHS2846bg8
    MHS2846bg8 [OP] Experienced Noob
    Nate
    South Coast of Oregon
    08 Tacoma TRD Dbl Cab 4x4 MT
    Hey y'all!
    Just wanting to get input on different types of winches and what y'all run for recovery purposes. I've seen the electrical vs hydraulic...
    So, which is better for light recovery purposes and what's the minimum load capactiy I should go with for light off-road recovery in my double cab prerunner? I was thinking 8000lbs is enough...
  2. Feb 12, 2011 at 2:43 PM
    MHS2846bg8
    Nate
  3. Feb 12, 2011 at 3:05 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    you want to go at least double the weight of your vehicle. when i get mine i am going for a 9,000 lb winch. aRb makes a great recovery kit i am going to get also. Need a winch bumper first. :D
  4. Feb 12, 2011 at 3:07 PM
    MHS2846bg8
    Nate
    Ok cool. Thanks for the info!
  5. Feb 12, 2011 at 3:10 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i have a warn m8000 on my 02 taco and it does more than needed
  6. Feb 12, 2011 at 3:11 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    There is a one, forget who makes it, but is a winch and air compressor combo, it was pricey, but if you can, go for it.
  7. Feb 12, 2011 at 3:46 PM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    07 Tacoma 4x4 SR5 V6 Off Road
    Lift,Winch,Shell,Light Bar,Siren,Radio's
    I have had SmittyBilt XRC 8000 for three years & used it over a hundred times to pull ton's of stuff. It's cheap to $ 289.
  8. Feb 12, 2011 at 3:51 PM
    Snoyota
    Snoyota Well-Known Member
    Taylor
    Marin County, CA
    07 Black Dbl Cab Sport
    3" King coilovers with resi, king rear shocks with resi, ome dakar leafs, 4xinnovation kickout sliders, CBI front bumper, warn M8000 winch K&N filter. Pioneer deckplate with 500w alpine amp and 13" Focal Sub
    Warn 9.5xp. its badass. Plus you want a winch that can pull twice your truck. Average tacoma weighs 4500lbs plus armor and people you are lookin at almost 5000lbs, i would get a 9 or 9.5 Warn
  9. Feb 12, 2011 at 4:03 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2 Anything in WARN and 9-9,5 size. We had a h9500i (or something like that - it's a gazillion years old by now). Damn awesome winch!!
    The 2nd gen trucks are actually above 5,000lbs (closer to 5100lbs). Here in PA, when you're over 5,000lbs that puts you in the next registration bracket and costs more money. The 1st gens are below 5,000lbs.
  10. Feb 12, 2011 at 4:09 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    just ordered m8000 warn :)
  11. Feb 12, 2011 at 4:38 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    my 1stgen dble cab v6 registration says 3700lbs
  12. Feb 12, 2011 at 5:57 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I have a warn m8000. When I first put it on I wanted to test it out, so I hooked it to a tree and held the brakes and it drug me without bogging down at all.
    Ive always heard that you need one that pulls 1 1/2 times your weight.
  13. Jul 8, 2011 at 3:49 PM
    james
    james In over my head...
    Friday Harbor, WA: Fairbanks, AK
    '98 Tacoma V6
    Why? I'm new here. My question seems stupid to you, but are you all hoisting your trucks so that they dangle from trees? Why on earth do you need such a powerful winch?
    I'm in need of a real answer here.
  14. Jul 8, 2011 at 5:08 PM
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, nc
    01 Tacoma Pre-runner
    Bilstein 5100's and OME 882's in the front AAL and Bilstein 5125's in the rear Converted to 4x4, with 97 front diff with manual hubs 4.56 Yukons front and rear Custom front bumper, sliders and under-belly skid by MOBS Fab in Concord,NC with built in hella's and 8000lb smitty
    x2 I got the SmittyBilt because it is cheap and has been very reliable
  15. Jul 8, 2011 at 10:58 PM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
  16. Jul 9, 2011 at 2:59 PM
    james
    '98 Tacoma V6
    Thanks, Layne. When I get a bumper, I'll have Eric over at Relentless fab me up an aluminum one and outfit it with a lighter weight one. (I only get stuck in the snow from time to time). The bumper weighs 58 pounds. I wonder what a lightweight winch would cost and weigh... hmmm...
  17. Jul 9, 2011 at 4:33 PM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    I would recommend a 8000-9500 lbs winch. With most available mounts you will need a non-integrated solenoid. The integrated ones need to be mounted feet down and most of the mounts for tacomas are feet forward (which is IMO preferable anyway).
    I have an XRC 8 and have had great luck with it (although I did seal up the solenoid really well as some people have had theirs rust up inside from poor seals). I would recommend it for occasional use. I am considering the Superwinch EP9 or the Talon 9.5, but I also like the X9. Warn makes good products as well and the M8000 is very popular but I'd still rather have the Superwinch, they also have a preferable solenoid to other brands (the albright).
    To accompany the winch I would suggest getting 2 3/4 shackles, a pair of leather gloves, a 3x30' strap, a tree strap, and a snatch block.
    http://www.wheelersoffroad.com/towstrap.htm
    http://winchline.com/
    http://allenmachineco.com/pages/data/mathan-5.htm Yarding block # 1250 (what I carry)
    I wouldn't recommend a kit but... good visuals
    http://youtu.be/qP766RaCTFY
  18. Jul 9, 2011 at 10:47 PM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    I had a Smittybilt XRC8 for over three years & did over 100 pulls with it & it Never let me down. It was cheep $$$ to. I just upgraded to a Warn XD9000 & a Ramsey 15,000. Now I just need people to go get stuck! lol :D
  19. Jul 12, 2011 at 1:20 PM
    Chickenmunga
    Chickenmunga Nuggety
    Hillsboro, Oregon
    08 TRD Offroad DC 4x4 (read the build)
    Based on your light needs, I would do one of the following:
    1. Get a hi-lift jack and the ORK kit. no need for a new bumper, you can use it on multiple vehicles, store it in the attic/garage for the off season. Also very inexpensive.
    2. Get an inexpensive winch. People seem to be happy with Smittybuilt, and you could also look at Harbor Freight (before you say boo, HF finished third in an offroad magazine torture test). It sounds like the winch is more of a convenience than needing to be a full on, i'm in the middle of nowhere about to die problem solver winch, so you don't need the rolls royce to get the job done. These budget winches should provide good service for the times you will need it.
  20. Nov 7, 2011 at 7:47 AM
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    Is the lack of responses a good thing? Has anyone found the M8000 to not be enough?
