Typical brake mileage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sfrichey, Jun 14, 2015.
  1. Jun 14, 2015 at 8:08 PM
    Sfrichey
    Sfrichey [OP] Member
    Albuquerque, NM
    2015 TRD Off-road 4x4 DCSB Silver tow pkg
    Saturday I noticed my '15 making a metal on metal sort of noise when moving, I think its brakes, even when brakes are not applied. Its always had lots of black brake dust on the front wheels, just like my '07 FJ always had. The Taco only has less than 10k miles. How many miles can you expect on the oem front brake pads?
  2. Jun 14, 2015 at 8:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If your brakes are worn out in 10K miles, one of two things are going on:
    1.) You have a mechanical problem. ( Caliper seized etc... )
    2.) You drive with your foot on the brake pedal.
    I have always gotten at least 100K on a set of front brake pads. My last truck had the OEM pads on it and it was a 1993 twenty years old traded it on my 2012 Tacoma.
    Arailt, RogueTRD and patbegley like this.
  3. Jun 14, 2015 at 8:45 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Same here. Replaced rear pads on my '06 Avalon awhile back. Had 182K on the clock - 3mm left on the pads - was within limit - changed anyway.
    As stated above, mechanical failure or riding the brake pedal will lead brakes to an early death.
    My mother could kill front pads in < 20K - rode the brakes...all the time.
  4. Jun 14, 2015 at 8:48 PM
    Abby
    Abby Abner, but good friends call me Abby
    Abner
    Alta Loma, CA
    2015 Tacoma Prerunner TRD Sport
    TRD Supercharger, TRD Exhaust, Black Rhino- Tanay rims, Leer tonneau
    Just replaced my wife's '05 4runner V8, brakes with 75K miles.
  5. Jun 14, 2015 at 9:23 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    take it to the dealer....
  6. Jun 14, 2015 at 9:34 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    Going on 80k on my original pads and will be replacing them in the next few weeks before I start towing my TT regularly again.
  7. Jun 14, 2015 at 10:35 PM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    While we're on the topic - do these new pads eventually stop kicking out so much dust?
    Pretty much daily I could turn a paper towel black from cleaning brake dust off my wheels.
  8. Jun 14, 2015 at 10:56 PM
    byrd
    byrd Unknown
    David
    Kansas
    '06 Access SR5 4x4 6 speed
    74k on my OEM's, had them checked at 70k still have plenty of pad on them. I have a manual trans so mine will probably last longer than one with an auto trans.
  9. Jun 15, 2015 at 2:25 AM
    JKD
    JKD Well-Known Member
    I'm about to hit 100,000 miles, and have about 50% left on the front pads.
  10. Jun 15, 2015 at 4:08 AM
    Capt Jrod
    Capt Jrod Well-Known Member
    Jarrod
    Northern Ohio
    15 WHITE DCSB 4x4 TRD SPORT
    Many variables apply including trailer towing, driving habits, and other drivers. If it is just you and you baby them, I think 75k is reasonable. I would recommend looking in the rear drums every 25k or so. Blow out the dust and clean them up then put them back. If you lift the truck, put on giant mudders, pull a trailer, and drive it like you stole it, then plan on 35k miles
  11. Jun 15, 2015 at 4:41 AM
    nm4553
    nm4553 You had me at "Meat Tornado"
    Nick
    NEPA
    2017 DCSB TRD Sport
    SCS Stealth 6 Matte Bronze on Toyo Open Country 265/70R17, Fox 2.5 Coilovers, Bilstien 6150 w/ Remote Resi, Dakar Leaf Pack, Wheeler's Bumpstop, OVTuned
    I had the same issue after I installed my lift - twice actually. Turns out the disc brake shield was rubbing against the rotor causing the "metal to metal" sound you are describing. If you use a long flathead screwdriver you should be able to push the shield out a but without having to take off the wheels.
  12. Jun 15, 2015 at 5:03 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Replaced my fronts at somewhere between 75 and 80k and they easily had 10k more in them.
  13. Jun 15, 2015 at 5:22 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Also it depends a lot on where you live, city driving will shorten the life. I live in the sticks and can drive for miles with out having to stop for lights or even a stop sign. 100K is fairly normal for me the rears will generally last twice as long as the fronts, my 97 had the original rear brakes when I sold it at 265,000 miles. I tow a camper and it looks like I'll get about 100K out of the front brakes on the "11" it's at 60K now
  14. Jun 15, 2015 at 8:02 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    oem toyota pads are not known to be really dusty. 33,000 on my tacoma, can't tell which
    wheels were on front longest, neither have much brake dust whatsoever (I rotate wheels every 7500 miles)
    now, if I installed EBC greenstuff, in 1000 miles my wheels would be black with dust
    patbegley[QUOTED] likes this.
  15. Jun 15, 2015 at 9:51 AM
    Sfrichey
    Albuquerque, NM
    At dealer, at 9500 miles front pads are less than .4 and rotors have heat spots, so they need replacing too. Pads are so worn Toyota won't cover under warranty but dealer doing a goodwill replacement. Don't tow and don't ride the brakes, so don't know why They wore out so fast. However where I live I think the traffic engineers own the brake shops
    Joe D likes this.
  16. Jun 15, 2015 at 10:05 AM
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    My 14 never had brake dust problems but when my mom picked up her 15 I noticed her wheels would be turning black.
  17. Jun 15, 2015 at 2:14 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Was the measurement on both sides or just one side. There is no way a properly operating brake system that is not being abused wore the brakes in 9,500 miles. If the above is true, you have a mechanical issue with a sticking caliper piston. Something is not right.
    Gatordog likes this.
  18. Jun 15, 2015 at 5:16 PM
    Capt Jrod
    Jarrod
    Northern Ohio
    Something is hanging up. Make sure they clean and lube everything and make sure they check them at the next oil change
  19. Jun 15, 2015 at 9:22 PM
    bigd9247
    bigd9247 Well-Known Member
    WA
    2024 TRD ORP, 2018 F150
    I got 60k out of mine and that was with 33's, towing, and lots of stop and go driving everyday
  20. Jun 16, 2015 at 1:55 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    Have it checked out!You may of been hard on your brakes and already worn down the pads to were the calipers are rubbing on the rotors and they also may be warped.
