Typical..."Help me decide which kit to get"
Discussion in 'Suspension' started by huckyourmeat, Dec 30, 2014.
  1. Dec 30, 2014 at 10:55 AM
    huckyourmeat
    huckyourmeat [OP] Well-Known Member
    Denver, CO
    19 TRD OR DC Silver
    Redline QL Plus hood struts, seatbelt chime off, cupholder mod, LED interior and license plate lights, Fumoto oil drain valve, Leer 100XR Mile High Edition, Kicker/tweeters, Kicker Key, Anytime + front camera, ECT anytime, 6112s (10/8), 5160s, Icon RXT (Stage 2, may drop to 1), Qi delete/dash pocket mod, TRD skid plate, alloy filter housing.
    Thanks for the great resource...I've been furiously reading as much as I can over the last few days. I'd like to do the install myself because I was quoted $5-600 locally to install without the UCAs. Seems really high.
    First off...2010 DCSB OR, TSB rear, stock everything else. I don't do much wheeling, but get out fishing and hunting a lot so spend a decent amount of time on fire roads. I also have a decently long city commute so spend a lot of time on road.
    I'm not wanting to change wheels and tires at the moment and really don't need anything too aggressive suspension wise.
    I'm looking at a package similar to http://www.headstrongoffroad.com/headstrong-kits-tacoma-05-6-lug.html or http://toyteclifts.3dcartstores.com/OME-Tacoma-Suspension-lift-kit_p_231.html and have a few questions...
    1. I'm pretty set on the OME front springs but torn between the 884 and 885. Is the only difference the length, or will the 885 be stiffer, too? I know the 885 is recommended for the Double Cab, but is that just so you get the 3" lift?
    2. Even if I'm only getting 2-3" of front lift, is it worth it just to do the UCAs now and be done with it? It doesn't see like they're that hard to install, am I mistaken? It seems like the Light Racing ones have a good reputation...
    3. I have the TSB rear springs. Trying to decide whether to go with Deaver add a leaf or with a 3-leaf like Icon. Which one has better ride quality on road? Off road? What about load capacity/sag?
    4. Should I pay the extra $150 to get OME shocks/struts instead of the 5100s?
    Is there anything else I'm forgetting? I plan on adding the driver side leveling spacer and not doing diff or CB drop and not extending brake lines based on what I read here.
    Thanks!!
  2. Dec 30, 2014 at 11:01 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    You will still need the top plate spacers for a full 3" of lift with the 885s.
    Here is some good coil spring rate info:
    http://www.tacomaworld.com/forum/suspension/301699-spring-coil-over-recommendation.html#post7678516
    New UCAs are highly recommended for anything approaching 2.5"+. That is to say some need them and some don't. Will alignment be much easier to achieve with new UCAs; yes. Love my LR UCAs.
    I would recommend swapping out the Toyota leafs. No matter what you add to them, eventually will fail. My single AAL lasted only 3k miles and then I swapped in a Dakar leaf pack.
    Use OME with OME. Don't mix and match. Do it once, do it right.
  3. Dec 30, 2014 at 11:04 AM
    Taco Libre
    Taco Libre Well-Known Member
    JohnnyHildo
    Saskatoon, SK
    2008 Black 4x4 Access-Cab TRD OffRoad
    Rear TSB, 5100s @ 0, Toytec 3" lift, Total Chaos UCAs
    i can only comment on a couple of things being i didn't buy an OME kit.
    the lifts between 2.5"- 3" are where you find the UCA's are pushed past the point of proper alignment. to keep everything in spec its best to get new UCA's.
    while i wouldn't say they were impossible i sure didn't find installing my UCA's a walk in the park. i watched a bunch of videos and read as much as i could get my hands on prior to installation but i would say if i spent a total of 14 hours with hand tools installing everything meticulously(front and rear lift and UCA'a) the UCA's were responsible for 6 or 7 hours of it. there is a lot of bending inner fender metal to get the bolt to clear!
    i also have the tsb and installed a deaver add-a-leaf into my stock leaf pack. the ride isn't much stiffer as far as i'm concerned and only really notice an extra buck when the rear tires go over speed bumps.
    i didn't have to extend brake lines for my lift either so you should be good as well!
  4. Dec 30, 2014 at 3:50 PM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    That's a little dire, isn't it? Did you haul a lot of weight with your AAL or something? Were your stock leafs already sagging when you added the AAL?
  5. Dec 30, 2014 at 3:52 PM
    geekhouse23
    Bed cap on it 99% of the time. Stock leafs had 5k on them when the AAL was added.
  6. Dec 30, 2014 at 3:58 PM
    NorCalTRD
    NorCalTRD Well-Known Member
    Northern California
    '06 Indigo Ink DCLB TRD Sport V6
    40% Front Tint, Viper 5704 Alarm, Steel Cable Dog Tie, Super Sexy Driver Mod
    OME full 3" kit with UCA and Dakar rear springs.
    You will be happy.
  7. Dec 30, 2014 at 6:02 PM
    huckyourmeat
    Denver, CO
    19 TRD OR DC Silver
    For the Dakars, are longer u-bolts the only extra thing I'll need? What about CB drop? Is that only if I experience shudder?
    What about brake lines?
  8. Dec 30, 2014 at 7:09 PM
    Taco Libre
    JohnnyHildo
    Saskatoon, SK
    any time you remove u-bolts you should replace them as they're designed to be a one use application. if you stick to just a 3" lift extended brake lines aren't necessary. and finally, spend the time to torque every bolt to spec and a lot of the driveline vibrations can be avoided. worked for me!
