U-Bolt Flip Kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by FirstTimeFirstGen, Mar 3, 2017.
  1. Mar 4, 2017 at 8:17 AM
    FirstTimeFirstGen
    FirstTimeFirstGen [OP] Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Sorry not really into Twilight. Is that a scene from the movie or am I just completely missing the joke?
  2. Mar 4, 2017 at 8:18 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^No, that's just Kristen Stewart in her red 1st gen.
    FirstTimeFirstGen[OP] likes this.
  3. Mar 4, 2017 at 8:22 AM
    04rktaco
    04rktaco Well-Known Member
    Lee
    California City, Ca.
    '04 4x4 xtra cab 4x4 TRD. 2014 Tundra crewmax TRD 4x4
    All Pro UCAs King coil-overs All Pro rear springs Modified All Pro Bumpers. Home made skids and sliders. Lefty 4.7 transfer case. Stock e locker rear stock 4:10's Tundra Brakes 285/75/16 Falcon Wildpeak AT3W stock wheels with 1.25 spacers BAMF lca skids. 2014 Tundra crewmax TRD 4x4 5.7 v-8 with leather interior. RCI Metalworks full set aluminum skidplates All Pro rock sliders
    I'm running the All-Pro flip kit. You can modify your stock bump stops to work. I welded them to the top of the new spring plate then bolted a universal energy suspension bumstop to where the stock bumpstop strikes then cut the stock bumpstop to get the uptravel I wanted.
    For shocks I'm running 10" travel Bilsteins that came with the All-Pro 3" springs I have and welded the mounts flush to the bottom of the axle. It's been a while since I installed all of it but think the shocks ended up being almost in the stock location maybe an inch lower which helps some.
  4. Mar 4, 2017 at 8:23 AM
    FirstTimeFirstGen
    David
    Pacifica
    Conflicted on how to deal with this. Part of me wants to buy all the rattlecan Walmart stocks and change the color of my truck immediately due to the Twilight reference. The other part of me acknowledges that Id do her in a heartbeat and that my (and her truck) have nothing to do with twilight.
  5. Mar 4, 2017 at 8:24 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
  6. Mar 4, 2017 at 8:25 AM
    FirstTimeFirstGen
    David
    Pacifica
    Thank you for all the info, but I don't like the shock location due to ground clearance. I appreciate the time and effort you put into your response. Thank you
  7. Mar 4, 2017 at 8:26 AM
    FirstTimeFirstGen
    David
    Pacifica
    COMAtized99[QUOTED] likes this.
  8. Mar 4, 2017 at 8:30 AM
    KenLyns
    Belly of the Beast
    Just don't rattlecan it light blue. Because Team Edward:
  9. Mar 4, 2017 at 8:36 AM
    KenLyns
    Belly of the Beast
    If all you do is slow crawling, cheap bumpstops will work. High-performance ones (as good as they get without hydraulic bumps) tend to be pricey, but they work with the U-bolt flip kit: [​IMG]
  10. Mar 4, 2017 at 8:37 AM
    FirstTimeFirstGen
    David
    Pacifica
    LOL Thank you for saving me from a great mistake!
  11. Mar 4, 2017 at 8:38 AM
    FirstTimeFirstGen
    David
    Pacifica
    Yup that's all I'm planning on. No long travel for me. There's a SAS in my future
  12. Mar 4, 2017 at 11:04 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Do the u bolt flip, its a cheap and easy mod thats one less thing to get hung up on. here: http://www.ruffstuffspecialties.com...t_Code=R2121&Category_Code=toyotaminitaco4run
    You can also order new bump stops through them and you should not need new shocks, you can compensate for length anyway by the location of you shock mount. You will also need to toss some washers in the upper shock mount to move the shock over a bit as it wont be aligned with the lower shock mount anymore. Search theres a ton of writeups on that.
  13. Mar 4, 2017 at 11:10 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    First I'm agreeing with @tan4x4 you don't need these. Especially if you don't have sliders. But whatever.
    I used the ruffstuff kit when I did my Chevy 63" spring conversion. Beefy kit.
  14. Mar 4, 2017 at 11:15 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Not sure how much you've actually wheeled before, but the axle clamp plates are not subject to much traffic underneath. Without doing your due diligence relocating shocks is a bit of work too, have to cycle you pack with just the main leaf to find your max and min lengths for shocks and then build an upper crossmember for the shocks and weld new tabs to the axle. Why not just use it for a bit, get a feel for it and when you're ready to buy new fully adjustable suspension components you can work out if you also want to fix the rear mounts. Really I've never scraped the lower mount and while there are plenty of good reasons to flip the u bolts and relocate the shocks, you haven't indicated any of them affect you yet.
  15. Mar 4, 2017 at 11:45 AM
    #35
    FirstTimeFirstGen
    David
    Pacifica
    You are correct in assuming I'm a novice. But what I don't want is to be the guy who holds up a group or even people behind me because I'm underprepared. This will be my first season, but i plan on doing as much as i can. Sliders will be ordered today. Skids will be made soon. I am a technician (diesel) so I do understand how suspension works and the importance of the geometry. I also understand ill have to find where I want to mount my shocks, stuff one tire and full flex the other to figure out my shock length requirements. I just assume people on this forum have done it before and was wondering if theyd impart their experience on me before I make the same mistake someone else has already made.
    303tacoma likes this.
  16. Mar 4, 2017 at 11:46 AM
    #36
    FirstTimeFirstGen
    David
    Pacifica
    thank you @slander
  17. Mar 4, 2017 at 11:48 AM
    #37
    FirstTimeFirstGen
    David
    Pacifica
    Thank you for your input @SnowroxKT
    SnowroxKT[QUOTED] likes this.
  18. Mar 4, 2017 at 12:09 PM
    #38
    Speedytech7
    If you are traveling with a good group of folks I doubt anyone would fault you for a little hangup and doubtless there is someone in the group who is eager to try a piece of recovery gear they bought. Its a team activity really :)
  19. Mar 4, 2017 at 2:23 PM
    #39
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    You're overthinking this! We got a guy with a 1st Gen in the group I wheel with sometimes. He's on KO2 285's, maybe 1 1/2" lift, and he goes everywhere the people on 35's and rocking Kings and lockers go. And he is OPEN diff. 1st gens were tough. Don't underestimate it before throwing a bunch of money at it.
  20. Mar 4, 2017 at 2:36 PM
    #40
    FirstTimeFirstGen
    David
    Pacifica
    So armor up and wheel it? It's just also my dd and I'd rather be overbuilt than break something
