U Bolt Issue
Discussion in 'Suspension' started by Prvbs2717, Mar 16, 2016.
  1. Mar 16, 2016 at 7:00 PM
    Prvbs2717
    Prvbs2717 [OP] Member
    I opted to put 2" blocks (for the time being) in the rear to level out, however, I seem to have hit a block.
    The U Bolts don't seem to fit correctly over the leaf springs and block. The U bolts will go, but, it's such a tight fit that the ends of the U bolt become spread too far apart and won't line up with the holes on the lower bracket. I attempted to squeeze them together but it doesn't seems as though they will squeeze together enough without bending.
    Is this normal?
  2. Mar 17, 2016 at 4:42 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Are you using blocks specifically intended for a Tacoma, or are they the generic "one size fits all" sort? I have a set of 1" blocks on my work bench that were on my Tacoma for a while. They were part of a kit specific to Tacoma's. There was ample clearance between the block and the U-bolts where they didn't touch. I've also got a set laying around the shop somewhere that came off of a '79 Ford 3/4-ton I owned years ago. (3") they are HUGE compared to the width of the Tacoma blocks.
  3. Mar 17, 2016 at 4:59 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    No. However you can probably grind a small amount of metal off the blocks so the bolts clear.
  4. Mar 17, 2016 at 5:41 AM
    Prvbs2717
    The box says they are for tacoma 2005-2015...the paperwork (instructions) inside says it's for 2005-2010. My Tacoma is a 2012.
    It's a "zone offroad" kit
    I'm wondering if the wrong kit was placed in the box or the wrong sticker was placed in the outside of the box. Maybe they just have poor quality assurance on their specs?
    I considered grinding some off but I figure I'll just return them and pick up another brand if it comes to that.
    Bluegrass Taco likes this.
  5. Mar 17, 2016 at 5:42 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Check with Headstrong Offroad if you need to buy again.
  6. Mar 17, 2016 at 5:53 AM
    Prvbs2717
    Will do. Thanks for the recommendation
