U-bolt replacement
Discussion in 'Suspension' started by catattacksdog, Sep 10, 2014.
  1. Sep 10, 2014 at 6:02 PM
    catattacksdog
    catattacksdog [OP] Well-Known Member
    Not Steve
    Not Kentucky
    07 dc
    Quick question: can I install a U-bolt flip kit buy simply removing and replacing the u-bolts? Or will I need to remove tire, front and rear leaf bolts, etc etc?
  2. Sep 10, 2014 at 6:10 PM
    Juan Solo
    Juan Solo Well-Known Member
    Johnny
    Houston
    2014 4x4
    It will be a world easier if you remove the tire, but other than that it is simple as swapping the old u bolts and plates with the new ones. Just make sure you have bump stops compatible with the new plates.
  3. Sep 11, 2014 at 11:48 AM
    catattacksdog
    Not Steve
    Not Kentucky
    07 dc
    Can anyone else corroborate this? Not that I don't trust Juan, I just want to make sure nothing will shift while I have those bolts removed.
  4. Sep 11, 2014 at 11:52 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    The center pin and the hangar for the leaf springs will keep the axle etc aligned. If you are worried, do one side at a time.
    Can't say that it was fun because you have to tighten the flip kit nuts and bolts by hand..tedious..
