U-Bolt Size for 4wd
Discussion in 'Suspension' started by badguybuster, Jul 9, 2009.
  1. Jul 9, 2009 at 6:19 PM
    badguybuster
    badguybuster [OP] Well-Known Member
    Michael
    West (by GOD) Virginia
    2016 Tacoma TRD Sport
    New truck....so nothing yet
    I need to order some new U-bolts for the TSB springs I bought plus an AAL. I am thinking 2" longer. Does anyone know the specs on the regular factory u-bolts. Tried looking it up in the repair manual. No luck.
  2. Jul 10, 2009 at 7:30 AM
    badguybuster
    Michael
    Um, hello??
  3. Jul 10, 2009 at 7:36 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Get under your truck and measure. ;)
    Seriously, that's your best bet. Buy the u-bolts longer than you need and cut them down after they're installed. Better to have too long than too short, and cutting them after installation guarantees proper fit without dragging the threads on the ground.
    You'll mangle the thread ends and will have to cut them off if you ever remove the leaf springs in the future, but no big deal because U-bolts really shouldn't be re-used anyway.
  4. Jul 10, 2009 at 7:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What he said ^^^^^^^^^^^^^^^^^
