U-Bolt size Need Help
Discussion in 'Suspension' started by NicksRig, Oct 15, 2009.
  1. Oct 15, 2009 at 5:25 PM
    NicksRig
    NicksRig [OP] Well-Known Member
    Kenora, Ontario
    07 Tacoma DC TRD Sport
    Blacked out Skid plate, block heater, bug deflector, blacked out headlights, tinted fronts, OME 3" lift, Toytec AAL, Revenge-Fab Sliders, K&N Air Filter
    I just purchased 4 u-bolts to install since adding a AAL. I realized after getting home that they are 1/2" whereas the factory U-bolts are 5/8"(correct me if I am wrong). Are these going to be strong enough or should I take them back and get different ones?
  2. Oct 15, 2009 at 5:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Take them back. Get the right size.
  3. Oct 15, 2009 at 5:29 PM
    NicksRig
    Kenora, Ontario
    Done! Thanks again.
  4. Oct 15, 2009 at 5:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  5. Oct 15, 2009 at 5:37 PM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    Your stock u-bolts should be 1/2". 5/8" on a u-bolt is huge.
  6. Oct 15, 2009 at 6:05 PM
    NicksRig
    Kenora, Ontario
    Like I said, I am not sure on the factory size (9/16"??). They just seem a little bigger than the 1/2" I bought at the store.
  7. Oct 15, 2009 at 6:13 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    Here is a pic of 1/2" cheapos grade 3 next to my 9/16" grade 8's. Stock should have been closer to 1/2" than 9/16". The 9/16" will fit your plates w/o drilling though. I've sold a couple pairs of 9/16" grade 8's to a couple X guys....
  8. Oct 15, 2009 at 6:18 PM
    NicksRig
    Kenora, Ontario
    The ones I bought are 1/2" grade 5. Should I just get beefier ones?
  9. Oct 15, 2009 at 7:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would get the same size/grade as the ones that were on there.
  10. Oct 15, 2009 at 7:31 PM
    Beefed Taco
    Brian
    My Metal Shop
    99 Taco
    1/2" grade 5 will be great. Just stay away from the cheapos at your local parts store. They're grade 3 China with a torque rating of 30 ft. lbs. Yours should be about 70-90 ft. lbs.These are my 1/2" grade 5 USA steel custom bent at the local spring shop I do a ton of business with. Even the threads aren't cut as deep so there is no play / movement in the nut at all. I highly recommend staying away from lock washers too. They'll deconform, crack, split & break and then your stuff is loose. Paint the threads when you're done so they don't rust and it'll all come apart nice when you need it to. I paint a white stripe on the rear of the nuts so I can *see* that they are tight.
  11. Oct 16, 2009 at 8:35 AM
    NicksRig
    Kenora, Ontario
    Thanks dude. I am going to go ahead and install the ones I bought yesterday when my truck is back from getting aligned. Whats the difference between the rounded ones like in your picture vs. the squared ones that come stock?
  12. Oct 16, 2009 at 10:32 AM
    sonjay
    sonjay Well-Known Member
    You wouldn't know what diameter the U bolts would be? I tried to flip my ubolts when I got my rear springs but couldn't find the right size u bolt.
  13. Oct 16, 2009 at 10:40 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    I just went out and measured my U-Bolts. They are exactly .510, so 1/2 is the winning ticket with a 'stock' setup.
  14. Oct 16, 2009 at 12:44 PM
    NicksRig
    Kenora, Ontario
    Perfect!:p
