U-Bolt Trimming?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cory07TRD, Aug 6, 2017.
  1. Aug 7, 2017 at 2:37 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    A cut off wheel on a grinder will be shitloads easier than using a hacksaw and a bit easier than using a sawzall.
    Wear some glasses, gloves, and long sleeves if you feel like taking care of your skin and eyes.
    Cory07TRD[QUOTED][OP] likes this.
  2. Aug 7, 2017 at 3:05 PM
    Doogz
    Doogz Well-Known Member
    Bryce
    Western MA
    2009 MGM AC
    yep..
    They will come off fine with no deburring if/whenever you decide to remove. An old trick is to thread a nut onto something before you cut it. Backing the nut off cleans the threads up, no need for a die. In this case, your nut is already there.
    stickyTaco and Justinlhc like this.
  3. Aug 7, 2017 at 3:42 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    One good trip off-road and the threads will likely get damaged anyways. They still come off the same.
  4. Aug 7, 2017 at 5:17 PM
    TucsonAZ
    TucsonAZ Well-Known Member
    2006 Crew Cab TRD
    ARB Bumper
    Wow, gotta love online, what is a simple job of taking an angle grinder to 8 bolt ends that would take no more than 5 minutes has turned into two pages of kits and deburring and retapping and flipping. In the time you spent posting this you could be done already. I will give you the best advice yet since you're already under the truck mucking with the axle, just install a set of Volvo Portal axles while you're down there.
    I love the web!
  5. Aug 7, 2017 at 6:23 PM
    Cory07TRD
    Cory07TRD [OP] Well-Known Member
    Cory
    Sacramento, CA
    07 Tacoma TRD
    Body Armor Rock Slider/Step, 5100's, Falken Wildpeak AT3W's
    Well said. I do like mucking with my truck though. Cause this me at work all day :pccoffee:. And working on my taco :rofl:
