U-bolts over torqued, now?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Charger92, Jan 28, 2017.
  1. Jan 28, 2017 at 6:43 PM
    Charger92
    Charger92 [OP] Built for pure function!
    British Columbia Canada
    2007 Tacoma double cab long box
    Well had leaf springs done on the recall and read previous some where about not being torqued right from the dealer.
    So after about 400miles on them, weather finally is dry and warm, I crawled under there and retorqued them as to a chart I had from years back, (1/2 grade 5 u bolts torque to 85-95ftlb) so I did @ 87ftlbs.
    Now coming on here reading and doing a bit of searching I see they probably should have been 73ftlbs.
    Should I loosen and retorque to the 73ftlbs or just leave them? Has the bolt or threads stretched or any ill effects been caused? Never dove yet at the 87ftlbs. Thanks for the help.
  2. Jan 28, 2017 at 7:04 PM
    Pigpen
    Dan
    Northwest Montana
    They're fine. better tight than under torqued in this case.
  3. Jan 28, 2017 at 7:09 PM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    Leave em, for sure, for the same reason you don't ever re use ubolts. They stretch when being torqued, so leave em and your fine.
  4. Jan 28, 2017 at 7:13 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    73 ft-lb was never substantiated. The service manual said 37 ft-lb, so people figured it was probably a misprint and should've been 73 ft-lb. 87 ft-lb is closer to the spec for 1st gen Tacomas.
    Most repair shops (including respected ones like South Main Auto) don't bother with a torque wrench or torque stick on suspension fasteners including U-bolts. They use a 1/2" drive impact gun and get them roughly to the 80-90 ft-lb range.
    Jimmyh likes this.
  5. Jan 28, 2017 at 7:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    WHat he said ^^^ 2 grunts and a fart.
    I torqued mine to 85 ftlbs.
