u-bolts too short for dakars
Discussion in 'All-Pro Off Road' started by especk, Feb 16, 2011.
  1. Feb 16, 2011 at 6:47 PM
    especk
    especk [OP] Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Hey guys, just wanted to say that the u-bolts that come with the flip kit are too short to work with dakar leafs. I was told they would be fine. Only half of the threads engage on the nut and that is without using the washers. Are longer u-bolts available to work with these leafs? Thanks.
    EDIT: THE U-BOLTS THAT COME WITH THIS KIT ACTUALLY DO WORK WITH THE DAKARS. THEY ACCIDENTLY SENT ME THE WRONG ONES. SO IF YOU'RE THINKING ABOUT RUNNING THIS SETUP, DO IT!
  2. Feb 16, 2011 at 6:54 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    i purchased the ome ubolts made for dakars but they are not flipped kit
  3. Feb 16, 2011 at 7:04 PM
    especk
    Erik
    Redding, CA
    Cool I may need to do that. We'll see.
  4. Feb 16, 2011 at 7:04 PM
    crf69
    Ohio
    ummm yeah
    oh you were asking All-pro....my bad:eek:
  5. Feb 16, 2011 at 7:05 PM
    jandrews
    '09 FourDubDee TRD OR
    Snip....ah, I see.
  6. Feb 16, 2011 at 7:05 PM
    especk
    Erik
    Redding, CA
    ... or whoever. Just want to let it be known. Mostly for TW and people who are thinking about doin this same setup.
  7. Feb 16, 2011 at 7:06 PM
    crf69
    Ohio
    ummm yeah
    he was....me and you shoulda lookd where he posted it:rolleyes:
  8. Feb 16, 2011 at 7:06 PM
    jandrews
    Yeah, my problem is I roll in and look at the front page for interesting topics. I pretty much ignore the rest of the info.
  9. Feb 16, 2011 at 7:09 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    x2
  10. Feb 16, 2011 at 7:10 PM
    crf69
    Ohio
    ummm yeah
    oh it's not a problem....its a sickness and i have it too:cool:
  11. Feb 16, 2011 at 7:14 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    most trailer and spring shops can make custom u-bolts. usually they're only about $10 a piece. just give them the diamiter of your axle and how long you need the threads. i had to get some made to fix a boat trailer. they work great.
  12. Feb 16, 2011 at 9:53 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    buy a rear block lift kit and use the u-bolts from it. just measure the ones you have and make sure the ones in the kit are long enough. any vato zone, o reilly, pep boys, etc should have them in stock.
  13. Feb 17, 2011 at 3:55 PM
    jandrews
    He needs u-bolts that'll fit the flip kit.
  14. Feb 17, 2011 at 3:59 PM
    especk
    Erik
    Redding, CA
    yup - different than stock type.
    I just called all-pro today and they dont have longer ones.
    I'm getting new ones built tomorrow from a local shop who does that kind of thing. They are goint to be the same as all-pros but 1.5" longer.
  15. Feb 17, 2011 at 4:06 PM
    The_Hodge
    SC
    i had to do what i said before. i have the ubolt flip kit and installed an 1/2" block that will made me. w/ the shims and the block installed, it was just too long to use the ones that came w/ the AP kit. the u bolts used in the AP are no different than any other u bolt out there. they're all shaped like a U. all you need to do is measure and make sure you get the ones from one of the kits that will be long enough to work for what you need.
  16. Feb 17, 2011 at 4:09 PM
    jandrews
    Not sure I like the decreased surface contact between the bolt and the axle...in any event, I won't have this issue I *hope*, still being on TSB springs with an AAL.
  17. Feb 17, 2011 at 4:11 PM
    especk
    Erik
    Redding, CA
    the stock u bolts are are flat so they sit flush on top of the leafs. When u flip em, they need to be round so they have the same curvature as the axle housing.
  18. Feb 17, 2011 at 4:12 PM
    jandrews
    Technically it'll work without like Hodge is saying, it'll just look goofy and I question whether it's safe.
  19. Feb 17, 2011 at 4:12 PM
    The_Hodge
    SC
    and the u bolts in the block lift kits are typically rounded
  20. Feb 17, 2011 at 4:12 PM
    especk
    Erik
    Redding, CA
    I agree.
