U bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by boggle, Dec 1, 2014.
  1. Dec 1, 2014 at 3:20 PM
    boggle
    boggle [OP] Active Member
    VT
    TRD
    Will I be able to reuse my stock 2013 ubolts if I am going with an add a leaf?
  2. Dec 1, 2014 at 3:27 PM
    zmw
    zmw Well-Known Member
    SATX
    2014 TXproBAJA
    none
    the safe answer is no, because it will depend on which kit you are using, you might be able to but you need at LEAST 3/4" of threads showing for it to be safe, and u-bolts are generally only 15-30$ depending on which vendor you're using.
  3. Dec 1, 2014 at 3:28 PM
    boggle
    VT
    TRD
    That's all I needed to know thanks.:)
  4. Dec 1, 2014 at 8:52 PM
    jguns2002
    jguns2002 Well-Known Member
    Deaver AAL reuses stock ubolts
  5. Dec 1, 2014 at 9:44 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    lol what do the extra 3/4 of an inch of threads have to do anything with strength, other than getting hung up on a rock fucking up shit.
    OP its simple, contact what ever manufacture AAL you are going with, ask how thick the AAL is. Look at your extra threads on your U bolts (the straight section of threads not the first 1/8th in of tapered threads) Is the AAL thicker than the extra threads you have.... if so need longer u bolts, if not stock u bolts will work.
    You should be able to easily get away with a single leaf AAL (i rock stock u bolts with the wheelers 2 in single aal) and you could probably get away with a 3 leaf progressive AAL without the stock overload spring in. (this is all on the stock 3+1 leaf pack) BTW wheelers gives you extra u bolts on their 3 leaf progressive AAL, although i much prefer the single leaf AAL for better load handling.
