u bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kinkrider101, Dec 11, 2009.
  1. Dec 11, 2009 at 4:28 PM
    kinkrider101
    kinkrider101 [OP] Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    what do you guys use to get the bolts loose.
  2. Dec 11, 2009 at 4:31 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Breaker bar and a pipe if necessary
  3. Dec 11, 2009 at 4:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Wrench....
  4. Dec 11, 2009 at 4:33 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    big daddy pull bar,six point impact socket
  5. Dec 11, 2009 at 4:36 PM
    kinkrider101
    santa barbara
    wheels and tires
    im going to try to put in a aa. I have no tools i have a socket wrench and all those wrenches. will i be able to get it off with a socket
  6. Dec 11, 2009 at 4:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should.
  7. Dec 11, 2009 at 4:39 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    Got mine off just fine with a socket and ratchet
  8. Dec 11, 2009 at 4:41 PM
    kinkrider101
    santa barbara
    wheels and tires
    ok thanks and if i get the tsb aal without having the tsb done, do i have to cut it or anything
  9. Dec 11, 2009 at 4:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nope.
  10. Dec 11, 2009 at 4:44 PM
    kinkrider101
    santa barbara
    wheels and tires
    thanks im going to try to install the aal and the rear shocks, and i might take the coilovers to the shop
  11. Dec 11, 2009 at 4:47 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    The rear is easy as hell...the front is a bit more complicated cause you have to compress the new coils and stuff...I helped a buddy and it was a pain, but worth the saved money...Just be carefull...Chris4x4 broke his damn hand on accident a few months ago :eek:
  12. Dec 11, 2009 at 4:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah....But that was while working on a set that wasnt install right. :eek:
  13. Dec 11, 2009 at 4:49 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    yea i know...them bastards :mad:
  14. Dec 11, 2009 at 4:52 PM
    kinkrider101
    santa barbara
    wheels and tires
    when i put the u bolts back on do i need to use a torqe wrench or the same socket
  15. Dec 11, 2009 at 4:53 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    you should use new u-bolts torqued to 87 ft/lbs
  16. Dec 11, 2009 at 4:53 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I used a ratchet with a long handle to get a good bite on em and tightened the hell outta it :)
  17. Dec 11, 2009 at 4:54 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    You can use stock...i mean the same ones
  18. Dec 11, 2009 at 4:55 PM
    kinkrider101
    santa barbara
    wheels and tires
    ok thank you how is the bup stop uninstalled?
  19. Dec 11, 2009 at 4:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Actually, you really shouldnt re use U bolts. You "can", but its not advisable.
  20. Dec 11, 2009 at 5:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    When you remove the U bolts, it comes right off.
