U-Haul tow dolly
Discussion in 'Towing' started by Rellik01, Nov 3, 2011.
  1. Nov 3, 2011 at 11:43 AM
    Rellik01
    Rellik01 [OP] Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Will be towing a 1999 Camry on a U-Haul dolly (front wheel drive) with my 2011 TRD Sport 2wd (Heavy duty tow package). Any advice for towing a car like this as I've never done it before.
  2. Nov 3, 2011 at 11:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Take your time and be mindful where you pull into so you don't have to try and back out.
  3. Nov 3, 2011 at 11:59 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    x2.... you cannot back up and keep your truck in 4th.
  4. Nov 3, 2011 at 12:02 PM
    Goldstar225
    Goldstar225 Well-Known Member
    Tom
    Central Arkansas
    2011 Pre-runner SR5 4X2
    Allow extra distance for braking and increase your following distance to other traffic. You'll have 3000 pounds pushing you when you try to stop.
  5. Nov 3, 2011 at 1:04 PM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Why can't you put a car dolly in reverse? :confused:
  6. Nov 3, 2011 at 1:13 PM
    Pugga
    Massachusetts
    ^^ This, unless you have have previous experience backing up hay wagons. Anyone who's tried this knows how much of a bitch this is to do!
  7. Nov 3, 2011 at 1:19 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    I towed a 73 firebird on a U-Haul dolly about 250 miles. Just mind the braking as stated earlier. On the highway it was hard to tell the car was behind me. Mine is a 4x4, and I kept it in 4th most of the time.
    Best advice...................Do everything smooth.
  8. Nov 4, 2011 at 2:41 AM
    Rellik01
    Craig
    Windermere, Florida
    Thanks for the replies
  9. Nov 4, 2011 at 8:10 AM
    LEX
    Houston, Texas
    100 Series LC
    While we're on the topic. Do you guys think it'll be ok to tow say a 2wd 1969 Chevy truck using a dolly w/o removing the drive shaft? It's only going to be about a 40-50 mile trip.
  10. Nov 4, 2011 at 8:12 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    I don't see any problem with this given that it is 2WD.
    Fink
  11. Nov 4, 2011 at 8:17 AM
    Pugga
    Massachusetts
    Check the weight of that thing against what the tow dolly is rated for. Those old metal bodied pickups can be pretty bulky.
    This is from Uhaul's website:
    Towed vehicle requirements
    • Front-wheel or all-wheel drive vehicles must not weigh in excess of 3,450 lbs.
    • Rear-wheel or four-wheel drive vehicles must not weigh in excess of 3,900 lbs and you must disconnect your driveshaft.
    • Must have a maximum outside-to-outside tire width of 72"
    • Must not exceed a body width (at the doors) of 75" Note: body widths over 72" must use late-model U-Haul Tow Dolly (identifiable by silver galvanized color)
    • Low-hanging equipment on the vehicle being towed such as spoilers, air dams, ground effects, etc., may be damaged by contact with the tow dolly during loading and unloading. Make sure there is enough clearance for these items.
    • Tow lights (tail/stop/turn) required at rear of vehicle being towed
  12. Nov 4, 2011 at 8:19 AM
    Fink
    Orlando, FL
    I stand corrected.
    I still wonder what the mechanical reason for this would be? I have to assume this is just to cover their asses, but I could obviously be wrong.
    I towed my 1985 4Runner on a U-Haul car trailer (not the dolly) - couldn't have been easier and the cost is not that much more. It will add quite a bit of weight though.
    Fink
  13. Nov 4, 2011 at 8:32 AM
    Pugga
    Massachusetts
    I would guess it's to cover their asses. That drive line spinning in the transmission I suppose could cause some sort of mechanical mishap if circumstances are just right (or if there was a pre-existing condition in the vehicle being towed). In all likelihood it'd be fine, hell if you get towed they don't pull the driveshaft, they just put you on the hook and off you go but according to Uhaul's recommendations it's not the correct way to go.
  14. Nov 4, 2011 at 8:35 AM
    Fink
    Orlando, FL
    Agreed - cheap insurance.
    Fink
  15. Nov 4, 2011 at 10:32 AM
    LEX
    Houston, Texas
    100 Series LC
    Thanks, I'll have to think about what I'm going to do.
  16. Nov 6, 2011 at 7:22 AM
    Rellik01
    Craig
    Windermere, Florida
    Thanks, went as smooth as can be
  17. Nov 6, 2011 at 7:34 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    Put it in 4th gear and keep it there
  18. Nov 6, 2011 at 7:41 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    X2..
    the tow dolly does not have any trailer brakes to help slow your ass down..so, make sure you have plenty of space. your truck wont slow down fast enough in a panic braking situation..i know this because i tow my crawler a lot with my taco. braking sucks even with the trailer brakes i have on my trailer.
