U joint/Axle noise from 2015 Offroad with 12k miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YBLegal, Apr 29, 2016.
  1. Apr 29, 2016 at 9:14 PM
    YBLegal
    YBLegal [OP] Well-Known Member
    Hey guys, I have 2015 Offroad with 12k miles and about a week ago truck started making sounds that is close to old brake squeaking noise / bad power steering pump noise. it was not consistent but mostly when I push the car bit and letting go of the gas (truck leans fwd) and that's when it happens and once it does won't stop... and during my research i found out U Joints could be making noise so I mounted a gopro and recorded sounds from multiple points and it is coming from connecting shaft U joint.
    Also both front and rear suspension is making squeaking noise as well...
    https://youtu.be/nIro-P-hgmQ
    Taking her into the dealer tomorrow and hopefully they can fix it and will keep you inform.
  2. Apr 29, 2016 at 9:31 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Have you put fresh grease into all of the u joints?
  3. Apr 29, 2016 at 10:37 PM
    YBLegal
    Going to have dealer deal with it for now :p
  4. Apr 29, 2016 at 10:42 PM
    2015WhiteOR
    Gainesville TX
    And I guess the other question is have you drive the truck through a lot of water?
  5. Apr 30, 2016 at 7:02 AM
    YBLegal
    I live in sunny California. It rain more than usual but I mean truck is little over 1 year and has 12k miles. Just because i went through some water it should not be doing this...
  6. Apr 30, 2016 at 7:16 AM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    Sounds like they just need grease. I'd shoot some grease in them before going to the dealer.... but that's just me.
  7. Apr 30, 2016 at 7:19 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Hmmmmmmmmmmmm mine did that for a little and the zerks took about 9 pumps of grease. And gone, just a thought.
    scottalot likes this.
  8. Apr 30, 2016 at 8:41 AM
    2015WhiteOR
    Gainesville TX
    So it sounds like you did go through some water...
    The problem here is that many of us owners have found that the driveshaft u joints are under-greased from the factory. When you go driving through a shallow river, there is always a chance that water will get into the u joints, and in your case it may have been exacerbated by the fact that the factory grease in them isn't particularly plentiful.
    The advice I can give to anyone who drives through high water is to become more aggressive about chassis and driveline lubrication. This means you should pump fresh grease into all zerks after each outing in water and pay attention to the CV axle seals and the rear axle seals. It costs practically nothing to do and ensures that you aren't ever going to run a bearing dry.
  9. Apr 30, 2016 at 8:44 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Kids these days...mounting a GoPro and taking it to the dealership instead of just grabbing a grease gun.
    2015WhiteOR and sr5vic like this.
  10. Apr 30, 2016 at 12:08 PM
    YBLegal
    Yes but its already at the dealer. next time!
    Good to know. its first truck for me so I Panicked:annoyed:!!
    Great advise. I will keep it in mind!! thank you.:bowdown:
    had to figure out where the sound was coming from! hey its my first truck. you live and learn! :cool:
  11. Apr 30, 2016 at 5:54 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Grease every oil change 5000 miles for trouble free drive line.
    YBLegal[OP] likes this.
  12. Apr 30, 2016 at 6:07 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Sounds like a carrier bearing squeal...
  13. May 2, 2016 at 9:47 AM
    YBLegal
    Is there a way to grease up the carrier bearing? Or does it have to be replaced?
  14. May 2, 2016 at 9:52 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Some guys have re filled w/grease by way of hypodermic needle but you need to make sure it is the carrier.. (OEM carriers are about $200 & change)
  15. May 4, 2016 at 7:35 PM
    YBLegal
    today's update. Dealer is replacing whole drive shaft including carrier bearing and states my passenger shock is blown so they are replacing it too...
  16. May 4, 2016 at 7:36 PM
    2015WhiteOR
    Gainesville TX
    Damn son what the hell did you do to your truck?!
  17. May 4, 2016 at 7:41 PM
    YBLegal
    hahaha LOL
  18. May 4, 2016 at 8:21 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Toyota policy is to replace the drive shaft instead of just repairing what is broken / worn. They will do the same for a blown universal joint....
    Crazy.
  19. May 4, 2016 at 8:30 PM
    2015WhiteOR
    Gainesville TX
    Call me crazy but I often wonder if a lot of these guys are just abusing the hell out of their trucks (since that seems to be the cool thing) and then getting the repairs done free through Toyota warranty....
  20. May 4, 2016 at 8:34 PM
    VLocos24
    VLocos24 Well-Known Member
    Call me crazy but isn't that what warranty is for haha
