U Joint End Cap Spinning in Yoke
Discussion in '1st Gen. Tacomas (1995-2004)' started by surfernv, Jan 5, 2020.
  1. Jan 5, 2020 at 11:05 AM
    surfernv
    surfernv [OP] Member
    Nick
    2001 Tacoma Xtra cab 4WD
    OME 881 front coils. Dakar rear leafs. Nitrocharger Sport shocks all around. Snugtop topper with Yakima racks.
    Hi folks! I'm running an 01 4wd taco Xtra can, v6 (5VZ-FE) and I have what I am assuming is a very not good issue with one of my universal joints and the yoke it's mounted on at the transmission output.
    The end cap of the u joint appears to spin within the yoke, shown in these videos:
    https://youtu.be/gaSnNNNcAaI
    https://youtu.be/ULlRA35TWG8
    The retaining clips are still there (c-clips internal to yoke), but as far as I understand things this should not be happening. The reason I dropped the driveshaft was vibration issues and suspecting bad u joint(s). Now that it's out I will replace all joints anyway, but I'm wondering if this yoke might have been damaged this allowing the u joint to spin within it.
    Basically, hoping someone here can with in on whether I need/should get a new yoke as well?
    Thanks in advance for any input and wisdom!
  2. Jan 5, 2020 at 11:33 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Yes the yoke "might" be worn but.... It would be a bit of a stretch to think more than one cap would seize to the joint and spin in the yoke. The cap seems to be both free on the joint shaft and loose in the yoke. If I had to guess I would say someone put in the wrong (undersized) joints. If the (correct) replacement joint presses in good and snug you will likely be good to go. We are only talking a few thousandths of an inch here, between "loose" and press fit.
    slander likes this.
  3. Jan 5, 2020 at 2:44 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    If you havent rockcrawled it and broken a u joint in there, I would just swap in an OEM (not a spicer or parts store POS) u joint and that will probibly fix it. U joints can do some odd stuff when they get wore out.
  4. Jan 5, 2020 at 8:30 PM
    surfernv
    Nick
    Awesome! New u joints all around then while the drive shaft is out and see where it goes from there. Thank you both for the input!
    slander likes this.
  5. Jan 5, 2020 at 8:53 PM
    Dino1
    Dino1 Well-Known Member
    Dean
    2000 Tacoma 4WD 5sp
    Stock for now
    I’m having a similar issue but the cap will rock within the yoke.
