U-Joint Grease Type? And new drive-train noise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TnShooter, Mar 12, 2015.
  1. Mar 12, 2015 at 11:03 AM
    TnShooter
    TnShooter [OP] The TacomaWorld Stray
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Is the preferred Grease type Lithium Based NLGI #2?
    And will #1.5 or #1 work?
    I've been hearing a different noise lately when I hit 55-65 mph.
    Almost sounds like tire noise but a lower "Roar / Whine"
    You can only hear it when you apply the gas and inside the cab.
    You can not hear it at all with the windows down. Wind noise drowns it out eaisly.
    I don't think I've ever had the u-joints greased since 2010 or in 45,000 miles.
    I seriously doubt Firestone does it when I get the oil changed.
    The sound might just be the tires, I finally have over 15,000 miles on the DynaPro ATM tires but you can't even tell it?
  2. Mar 12, 2015 at 11:30 AM
    gimmeajo
    gimmeajo i'm here for the food
    Zander
    New Orleans via New England
    '13 DCSB 4WD TRD OR
    OME 883, N140, N182, 265/75/16 Hankook ATMs, Weathertechs, chop front flaps, diff breather, killed seatbelt dinger
    I use Red n Tacky every 5k. Wouldn't bet on Firestone doing it, but ask 'em next time, maybe they will. Easy job to do yourself though.
    I have new ATMs, no noticeable road noise. Hope is doesn't start with age, would think as a tire wears down noise would decrease as tread wears...
  3. Mar 12, 2015 at 11:36 AM
    TnShooter
    Deogee
    STOCK
    Love the ATM Tires. Best upgrade I've done so far.
    Hope the price doesn't go up On them. Best value tire I found.
    But I've found with other tires noise increased with wear.
    As for the grease , I plan to do it myself soon.
  4. Mar 12, 2015 at 1:29 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    For the grease is really doesn't matter so long as its fresh... I do mine every oil change while I'm under the truck letting oil drain.
  5. Mar 12, 2015 at 3:28 PM
    gimmeajo
    Zander
    '13 DCSB 4WD TRD OR
    does grease go bad??:notsure:
  6. Mar 12, 2015 at 4:18 PM
    nd4spdbh
    SoCal
    it gets crap and moisture in it.
    i use marine wheel bearing grease in my grease gun... and flush the u joints completely every 5ish k mi.
  7. Mar 12, 2015 at 6:16 PM
    TnShooter
    Deogee
    STOCK
    I would think it is fine. I don't feel any pulling left or right.
    I see no sign of wear on the tires to indicate the alignment is off.
    I don't know. Hope hope not. But it's not uncommon to see them go before 100,000 miles. I don't hear the noise when I turn left or right.
    Which is usually the sign of a bad wheel bearing.
    I only hear it between 55-70 mph. And only when press the throttle.
    Let off the throttle and the noise is gone.
    Running them at 34 psi and I have about 21,000 miles on them.
    I rotate them every 6,500-7,500 miles. Between every other oil change.
    I have free lifetime rotate, so I use.
    I don't know how much mine have wore. But not much that I can tell.
    I figured they would get louder after some wear. So that's ok. I haven't done any heavy off road trails with them. But they do seem to clear tread well. Only down side I found so far is they do pick up small rocks pretty easy. But I knew that going into it. It's part of having bigger lug tires.
