U Joint Grease
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeepsrwack, Jul 29, 2016.
  1. Jul 29, 2016 at 1:46 AM
    jeepsrwack
    jeepsrwack [OP] Well-Known Member
    2014 Tacoma trd sport
    I greased my u joints using Mobil 1 but noticed it leaks out of my grease gun in the hot garage. I noticed some splatter under the truck which may have been what I didn't wipe off. Do you think the grease leaks out on its own? Which grease should I switch to if anything to prevent leakage? Thanks.
  2. Jul 29, 2016 at 5:58 AM
    Caprizzy
    Caprizzy Well-Known Member
    David
    Lake Stevens,WA
    2013 Silver Streak Mica, DCLB TRD Sport 4x4
    GO HAWKS!!
  3. Jul 29, 2016 at 6:55 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    When the joints are greased it pushes out old grease the rotating drive shaft throws it out some lands on the truck look at it as rust proofing.
    Sig45 and ecgreen like this.
  4. Jul 29, 2016 at 7:38 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Your grease gun leaking is quite different that a U Joint leaking. I use Mobil 1 grease in my gun and there's a little leakage here & there on the gun. Doesn't bother me enough to worry about it.
    As maineah (fellow Maineah here too) stated....any splatter is a result of the old grease being squeezed out of the fitting. Highly unlikely your U Joints are leaking grease.
  5. Jul 29, 2016 at 8:23 AM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    There's always some amount of splatter if the u-joins are greased properly. It's when you don't see any grease that it's a problem. I use Valvoline Crimson grease and it oozes out of the grease gun a little bit because it's under pressure.
    TexasInfidel likes this.
  6. Jul 29, 2016 at 9:02 AM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
  7. Jul 30, 2016 at 4:01 AM
    jeepsrwack
    Thanks just wanted to make sure I'm good using the Mobil 1 grease
  8. Jul 30, 2016 at 4:08 AM
    Sig45
    Mark
    Maine
    Mobil 1 is perfectly fine...you're good to go! Good to grease those joints at each oil change & more often if your truck sees a lot of water.
  9. Jul 31, 2016 at 10:48 AM
    TexasInfidel
    TexasInfidel Well-Known Member
    Mystic Red Sticky,good enough for my Peterbilt,its good enough for a Tcao
    Larzzzz likes this.
  10. Jul 31, 2016 at 3:09 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    The Mobil 1 grease you are using, is it NGLI #2? #2 is a higher viscosity grease than #1, and better in warmer temperatures, while #1 will outperform #2 in cold temperatures. #2 is recommended for general purpose and u-joints in a wide range of temperatures that cover the vast majority of where Tacomas will be found. If you can't pump #2 out of a grease gun, and use polar bear hide of penquin skin to wipe your hands at the end of the job, then consider #1. :)
  11. Oct 9, 2016 at 4:36 AM
    TexasInfidel
    Properly greasing is less common
    You have to push out the old till you see the new.
    The more new you see the better you greased it.
  12. Oct 9, 2016 at 6:35 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    The u joints are definitely leaking the grease. The centrifical force of the rotating drive shaft is throwing all the grease to the outside of the spider.it will push through the bearings and out the little Rubber seal at the end of the cap.
    Unless the spider is cracked of course...
    Nothing to worry about tho. The needle bearings are always getting fresh grease.
    The zerk usually squirts a little as it's seal closes. Push on the little ball at the end of the zerk, it should pop back to close.
    Nessmuk likes this.
