U-Joint Greasing Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HMA, May 26, 2011.
  1. May 26, 2011 at 12:46 PM
    HMA
    HMA [OP] Well-Known Member
    Hal
    Bainbridge, Ga
    '10 Tacoma 4x4 Surveying Machine
    2010 DC LB 4x4. I searched and can't find an answer to this: I greased them for the first time today. I noticed that these U-Joints have a small hole in each "leg" near the bearings. As I pumped grease in, it came out of some, but not all the holes. I covered those that oozed with my fingers and was somehow able to pump the gun until it came out of the other one(s). The best I remember, greasable U-Joints I have dealt with in the past didn't have these holes. The grease came out of the bearing caps.
    Questions:
    DId I do the right thing?
    Are they all like this?
    The last few vehicles I have owned had sealed U-joints, why did Toyota use greasables?
  2. May 26, 2011 at 12:54 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    yes u did the right thing. its quick and easy greae them till u see or hear the little grease coming out=done. yes they are all like that. and im not sure why toyta decided to use greasables.... actually on alot of the AWD models like the rav 4 or sienna have sealed u-joints... i dont get it either ha. but yes good to hear ur greasing urs:cheers:
  3. May 26, 2011 at 12:56 PM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build
    What type of grease does it call for? lithium or what? im heading to the parts store today and need to get a tube and didnt know which type to get, there are like 6 or so dif kinds so i got confused last time i went to get my oil change stuff.
  4. May 26, 2011 at 12:58 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Last time I used red n tacky #2. I forget what's recommended but that or most other synthetics will work. Seems like mobil 1 synth is pretty popular
  5. May 26, 2011 at 1:01 PM
    lotsoftoys
    Jace
    Denver
    bunch of crap
    any u joint or bearing grease will work.
  6. May 26, 2011 at 1:03 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It's a grease zerk.
    Pop it on, shoot a couple pumps till you hear a seal or two releasing pressure, rotate the driveshaft to work the U joints, wipe up the extra so it doesn't make a mess.
    No overthinking required.
