U joint help required
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ZEROPILOT, Apr 28, 2022.
  1. Apr 28, 2022 at 2:49 PM
    ZEROPILOT
    ZEROPILOT [OP] Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    I have a 2009 Tacoma access cab with the 4 cylinder engine and 5 speed stick. Rear wheel drive only.
    I can't get a clear answer as to what U Joints I need for my 2 peice axle.
    Does anyone know what Ujoints I need? Maybe with some SPICER part numbers?
    I'd be very grateful
  2. Apr 28, 2022 at 2:52 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    ‘Berta
    06 Rad Red DCLB SR5, ‘25 SS Red Sport Prem. (on order)
    ZEROPILOT[OP] likes this.
  3. Apr 28, 2022 at 3:19 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    You can also use the greasable ones, both will fit. I recommend going this route so you can more easily maintain them. They will last much longer than their sealed counterparts in my past experience.
    I just went with some Spicer 5213X (5-213X) one’s bc I couldn’t find the 5-1330-x ones I usually use.
    SR-71A, TnShooter and ZEROPILOT[OP] like this.
  4. Apr 28, 2022 at 3:26 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    I used these. Front and back are easy, middle is a bitch. In retrospect I wish I'd paid a little money for a shop to do them if I brought it in.
  5. Apr 28, 2022 at 6:59 PM
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    So, three of the same?
  6. Apr 28, 2022 at 7:00 PM
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    I probably will just carry it into a shop with the new parts.
    My joints are still fine. But the things are like 13 years old
  7. Apr 28, 2022 at 7:53 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    never bring your own eggs into a diner.
    Oldewing1800, tak1313 and Robnik like this.
  8. Apr 28, 2022 at 7:57 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I say, don’t fix what’s not broke?
    But that’s probably because I’ve broke stuff that didn’t need fixed.
    As the saying goes, “To each their own”
    6 gearT444E[QUOTED] likes this.
  9. Apr 28, 2022 at 7:58 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    yes that too. Age has little to do with reliability and service life of the ujoints. Mileage, environment, and PM history are key.
    Key-Rei, Robnik and TnShooter[QUOTED] like this.
  10. Apr 29, 2022 at 6:05 AM
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    I'm currently working part time at a place where I get a giant discount on auto parts.
    I want to get the parts while I can. And use them whenever.
    I need three of the same Spicer U joints?
  11. Apr 29, 2022 at 6:41 AM
    Fullboogie
    Dave
    Houston
  12. Apr 29, 2022 at 10:43 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If you have a two-piece shaft, you likely have a center bearing which I would also replace. If those parts have 150K+, I would replace them. I replaced mine with Spicer non-greasable.
    Key-Rei likes this.
  13. Apr 29, 2022 at 3:10 PM
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    I bought the Spicer joints.
    And the center support bearing.(Precision brand) All four parts were just under $95. I got a good discount.
    I live in south Florida and my Taco has about 80k. It has larger than stock wheels and tires and does no towing, etc.
    It's been extremely reliable. And I'm big on proactive maintenance.
    I also bought all new radiator hoses, belt, tensioner and idler pulleys. And some Toyota PINK coolant.
    They were also all original.
    Thanks for the assistance
    6 gearT444E likes this.
  14. Apr 30, 2022 at 3:39 AM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    You can get your spicer u-joints & spicer center bearing on rockauto or summit racing. They will be sold under Dana. If you are the type of person that likes to set it and forget it then get the non-greasable u-joints. Otherwise get greasable and grease it at every oil change.
    Dana 51330x non-greasable.
    Dana 513301x greasable.
    Dana 5002334 Center bearing.
    These are the same parts as what you get at toyota but with out the toyota price.
    I would also recommend to buy an extra set of snap rings. I ended up needing thinner rings than the ones that came in the packaging and these ended up working for me.
    https://www.amazon.com/gp/product/B08GPF8XM4?ie=UTF8
  15. Apr 30, 2022 at 4:14 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    This tread is an example of the BEST of TacomaWorld!
    Guys asks a question and informative and factual answers start rolling in without any BS smartass comments or attitude! :thumbsup::thumbsup: There may be hope for this world yet :thumbsup::thumbsup:
  16. Apr 30, 2022 at 10:55 AM
    Chuy
    Lakeside, CA
    Silver Taco
    @ZEROPILOT I should have mentioned to stick with OEM/Dana/Spicer on the center bearings. I tried two different aftermarket center bearings and both barely lasted 20K. Neither were Precision; hopefully, that is a better aftermarket brand. They may be the same company that makes, or used to make, front wheel bearings for 4x4 models and they gave me good service life.
