U-Joint issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NmapFE, Sep 7, 2022.
  1. Sep 7, 2022 at 5:13 PM
    NmapFE
    NmapFE [OP] Well-Known Member
    2014 DCLB 4x4 Limited. 6112’s/5125, KYB Top Hats, SPC UCA’s, Icon RXT leaf pack,
    So started hearing this kind of “popping” sound like when you turn the wheel and ball joints are all jacked … but this sound only comes from the back of the truck and only when hitting the gas or slowing down. I’m thinking it’s the u-joint in the rear after installing my lift about 2 months ago.I’ve the drop for the driveshaft that came with the lift kit and thought I’d install that to see if it helps with the angle. With about 78,000 mile I was thinking maybe I should replace the unjoints then install the spacer so I’m working from a good starting point.
    Any thoughts? It’s a 2.5” lift (see signature for details).
    Fyi… I have no vibrations while driving or reving the engine and the driving is smooth as glass. Just this new pop sound .
    If I do need to replace them… are there better brands than others? Stock? Your input is appreciated.
  2. Sep 7, 2022 at 6:02 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Spicer replacements are just fine. I think they are the oem supplier. The only true way to test the u joints is to take the driveshaft out. If there is any resistance that isn't normal then they need replaced. At that point I would do all of them. If you just want to check the u joint at the diff then you can just disconnect it there. if you do remove your driveshaft make sure the wheels are blocked.
    NmapFE[OP] and Steves104x4 like this.
  3. Sep 7, 2022 at 6:13 PM
    NmapFE
    Thanks! What about upgrading to a Moog “Super-Strength” u-joint?
    Note: chalk wheels, replace all - got it
  4. Sep 8, 2022 at 5:35 AM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Up to you on which to choose. Do some searching. I couldn’t tell you any recommendations other than the OEM spicers because I haven’t needed to do mine yet.
  5. Sep 8, 2022 at 7:59 AM
    NmapFE
    Do you think the noise could be something else? Trying to consider what I am not thinking of.
  6. Sep 8, 2022 at 8:19 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I highly recommend upgrading to the non greaseable spicer units. They have a white seal and have 3 o rings vs the 2 in the blue seal zerk units.
    The greaseable zerks fail quite fast and are weaker due to the cross section being tapped for the zerk.
    I replaced mine every 6-8 months with the blue zerks. I went through about 3 sets. The non greaseable zerks I have been going on strong for 1.5 years without any issues.
    NmapFE[OP] likes this.
  7. Sep 8, 2022 at 9:33 AM
    AJKlug1
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    It’s could be. Inspect your leaf packs for broken leafs. Those can pop when broken
    NmapFE[QUOTED][OP] likes this.
  8. Sep 8, 2022 at 10:10 AM
    NmapFE
    The RTX packs are new but I’ll definitely check them
  9. Sep 8, 2022 at 7:46 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    There are different grades of greasable ones as well, so not all are created equal.
  10. Sep 8, 2022 at 10:59 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    What would you recommend? I've only ever used the spicer units, which is what my experience is limited to.
  11. Sep 9, 2022 at 5:29 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    the SPL are higher quality than the 10 series.
  12. Sep 9, 2022 at 6:29 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    Stay away from Moog...their quality has considerably declined...Me personally, if you do your own MX, and get under your truck alot, grease your U joints when you do, Id do greaseable vs sealed, just my opinion.
