U-joint Lube
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rhelms911, May 9, 2016.
  1. Jun 8, 2017 at 8:19 PM
    Nedrolls
    Nedrolls Well-Known Member
    Scott
    Coquille, Oregon
    1999 Ext cab beater. 2016 Pro 4Runner(wife's)
    Grease-less u-joints are becoming increasingly popular. Kenworth guy told my friend that the grease-less joints on his new log truck will outlast standard joints, or he'll pay to replace them.
  2. Feb 13, 2018 at 2:41 PM
    felkebg
    felkebg Well-Known Member
    Bill
    Auburn AL
    2017 Tacoma
    Just took my new 17 tacoma 4X4 in to check and front two zerks were full of factory grease and they will not check again till 5000. Rear shaft is zerkless and sealed. Confirmed they do not inspect at PDI
  3. Feb 13, 2018 at 2:52 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The front zerks on my 17 took about 4 or 5 pumps to fill.
  4. Feb 13, 2018 at 3:42 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Here's my thoughts on that kind of statement.
    It probably holds true, because proper maintenance is not being performed on the greaseable u-joints.
    Technically, each time a greaseable u-joint is exposed to an inordinate amount of sand, mud or water, they should be greased afterward.
    Even tells you so, in the Toyota maintenance manual.
    I would speculate most end users do not perform this task; including your friend who is exposed to those kinds of conditions daily.
    shakerhood likes this.
  5. Feb 16, 2018 at 9:58 PM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    At least you have rear zerk fittings.
  6. Feb 17, 2018 at 4:48 AM
    Cole man
    Cole man I like a clean taco....
    Paul
    Bluegrass state
    2017 tacoma SR 4x4 V6 MGM
    Stock so far
    I dont seem to have any zerks at all on mine.
  7. Feb 17, 2018 at 5:10 AM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    You mean front
  8. Feb 17, 2018 at 5:30 AM
    STPJ07
    STPJ07 Well-Known Member
    Florida
    2017 OR TRD 4x4
    In my catalog it shows somewhere around 10/11 -2017 they started changing them over to no zerks.
    If you have a 4wd you still have them in the front shaft.
    Cole man[QUOTED] likes this.
  9. Feb 17, 2018 at 6:07 AM
    Cole man
    Paul
    Bluegrass state
    Stock so far
    After i didnt find any on the back i gave up and didnt check the front. Thanks for the info
    STPJ07[QUOTED] likes this.
  10. Feb 17, 2018 at 9:18 AM
    shakerhood
    Southern Ohio
    They are still on the front driveshaft.
