U joint maybe?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thomasn, Dec 13, 2017.
truck has slight delay taking off in first gear
  1. u joint?
    50.0%
  2. rear diff?
    50.0%
Multiple votes are allowed.
  1. Dec 13, 2017 at 12:41 PM
    thomasn
    thomasn [OP] New Member
    thomas
    2008 Toyota Tacoma Pre runner srs
    hey guys, so this is my first automatic vehicle i've ever had. it's an 08 tacoma with 28k miles. This could just be paranoia being my first automatic and all but every my truck shifts past second gear, when I stop and take off again there is a slight delay, doesn't sound too bad and it only does it in first gear. shifts into drive, reverse, park and all the other gears with ease. but when I completely stop and take off again, it's rougher than all the other gears. It feels like my driveshaft is spinning but just takes a half second for the rear dif. to catch. my buddy told me it could be my U joint but i honestly have no idea. does someone know what i'm talking about or is it all in my head?
  2. Dec 13, 2017 at 12:43 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    If it's diff it seems you would hear gears grinding.
  3. Dec 13, 2017 at 12:44 PM
    thomasn
    thomas
    no gears grinding
  4. Dec 14, 2017 at 2:02 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    sounds like transmission problem check the fluid
  5. Dec 14, 2017 at 3:22 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    When was the last time you inspected the u-joints and greased them if possible(prerunner may not be able to grease)?
  6. Dec 14, 2017 at 6:57 AM
    thomasn
    thomas
    - never. i just bought the truck around 10k miles ago. i'be been looking and a lot of people are saying get the transmission re flashed, think that could be it? or should i grease the U-joints first?
  7. Dec 14, 2017 at 7:07 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I doubt this is not a u joint or diff issue
    Sounds like low tranny fluid. does it do it less when warmed up?
    does it shudder cold around 40 MPH in D?
    a few people on here had their tranny fluid dumped instead of engine oil and what you describe is the end result of not enough fluid
  8. Dec 14, 2017 at 7:19 AM
    thomasn
    thomas
    it does not shudder around 40; from first to second is the only time it ever happens. i'm takning it in friday. gotta love those "sealed" transmissions. i think it is low fluid tho. my output shaft was leaking so i replaced it. not sure how long it was leaking tho, and it never same to a drip. just a class 2 drip where if creates a bubble but never falls
  9. Dec 14, 2017 at 9:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Neither.
  10. Dec 14, 2017 at 9:59 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    10 year old truck with 28,000 ?
