U joint or control bearing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JIsabelle218, Apr 23, 2024.
  1. Apr 23, 2024 at 9:27 AM
    JIsabelle218
    JIsabelle218 [OP] New Member
    Greetings,
    I have a 2010 taco TRD sport, V6, quad cab long bed.
    Recently have a loud squeak from the rear with the vehicle is in Drive and moving (squeak appears to be rotational). Audible at low speeds, undetermined if it's audible at high speeds. No sound in neutral while rolling or in reverse at rolling. Going to climb under this afternoon when I get home and poke around. Curious to thoughts and recommendations. Intermediate skill level and own a grease gun
  2. Apr 23, 2024 at 10:00 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Drop the driveshaft and check the u-joints
    wi_taco, Jimmyh, Dm93 and 2 others like this.
  3. Apr 23, 2024 at 12:53 PM
    TacoTuesday1
    SD CA
    you can grease, inspect, and rebuild shafts
    never heard of them squeaking
    my leafs squeak sometimes in certain conditions but that seems normal
  4. Apr 29, 2024 at 8:26 AM
    joesmaro
    joesmaro New Member
    Joe
    2009 Silver Tacoma TRD Off Road
    I have the same problem. Everything I’ve read points to U-joints. I also have vibration. I’ve lifted my truck a couple inches with Bilstein shocks and a spacer in the back. Put a drop kit in it the other day and that seemed to eliminate most the vibration. Installing new u-joints and carrier bearing today.
    This is exactly what mine sounds like.
    https://youtu.be/4J9iy67R31M?si=FAuS068h7OTND0cB
