U-joint replacement for 1998 4wd tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1998purplepickup, Apr 7, 2018.
  1. Apr 7, 2018 at 12:45 PM
    1998purplepickup
    1998purplepickup [OP] Well-Known Member
    St. Michaels, MD
    1998 4wd 2.7L Tacoma
    warn vr 8-s winch welded rack and canopy LED bars front and rear Front and rear diff breather ext. lift
    Im looking to replace my u-joints. hearing squeaking from the rear and vibrations under the cab area and sort of in the pedals. I am not a mechanic. I do research and do what i can or have my mechanic do fixes depending on costs.
    I have not greased my u-joints.
    Any recommended part #?
    I found these MOOG super-strength part #285 https://www.autozone.com/drivetrain/u-joint
    If there's a better cost-comparable part, I wanna know.
    thanks.
  2. Apr 7, 2018 at 1:26 PM
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    Interested as well because I’ll be doing this in the near future
    1998purplepickup[OP] likes this.
  3. Apr 7, 2018 at 4:24 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Wrote up the process when I just did my u-joints (which were toast). The part number you want if you want to go OEM (I like OEM) is 04371-60070 and the cost isn't all that much ($50 at the time I wrote this).
    QMEDJoe and 1998purplepickup[OP] like this.
  4. Apr 7, 2018 at 4:31 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    You can also order matsuba u joints from low range off-road. That's the OEM supplier to Toyota.
  5. Apr 7, 2018 at 5:35 PM
    1998purplepickup
    St. Michaels, MD
    ah, thanks!
    This part description says works for up to the 95. but i have a 98. http://www.lowrangeoffroad.com/u-joint-matsuba.html
    is this going to make a difference or are the u joints the same for the 98?
  6. Apr 7, 2018 at 6:03 PM
    slander
    Hickory, NC
    I think they work on everything but the u joints on the CV. Give them a call to be sure before trusting that random dude on the net!!
  7. Apr 8, 2018 at 12:32 PM
    1998purplepickup
    St. Michaels, MD
  8. Apr 10, 2018 at 8:34 PM
    1998purplepickup
    St. Michaels, MD
    so this part that the internet told me matched my vehicle did not. so now everyone else knows. the spicer 5-153X u joint does not fit to replace the rear driveshaft to diff u joint on a 1998 4wd 4cyl 2.7L standard cab tacoma.
  9. Apr 11, 2018 at 5:45 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Thanks OP. I did just install the OEM one I linked above, and it of course fits fine.
  10. Apr 11, 2018 at 6:19 PM
    1998purplepickup
    St. Michaels, MD
    Thanks! i actually followed your link first, but the site said it wouldn't fit my 98 truck. Not sure why, but i found one at my oreillys today for $17.99 that worked out. thanks for the help!
  11. May 28, 2018 at 9:52 AM
    1998purplepickup
    St. Michaels, MD
    the u-joint that worked out for my 98 tacoma rear u-joint replacement was PRE 387 $17.99 at oreilly's.
  12. May 28, 2018 at 1:50 PM
    tony2018
    tony2018 Well-Known Member
    Not all u joints are for the same location. Be careful
  13. May 28, 2018 at 2:32 PM
    gotboost
    gotboost Member
    Bud
    04 DC Tacoma
    +1
  14. May 28, 2018 at 3:19 PM
    1998purplepickup
    St. Michaels, MD
    Always make sure the parts are the right fit. Definitely a good thing to keep in mind when replacing any one of them.
  15. May 28, 2018 at 4:03 PM
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    I went with the MOOG SuperStrengths. Feel much better than the old ones and look better too
  16. May 29, 2018 at 7:10 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    You should be able to pull up Autozone or OReillys etc. online and see if the U Joint part numbers are different. Depending on location. Also you can look up how many years are covered by one part number.
  17. Jun 8, 2021 at 10:58 AM
    98_3RZ_NIC
    98_3RZ_NIC Well-Known Member
    1998 white extended cab
    Bilstein 5100’s with ome 881 coils on lowest setting, JBA upper control arms, LCE header, 31x10.5x15 falken wildpeaks.
    I have a 98 Tacoma 4x4 xtracab 2.7L. Will these fit?
