U joint replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mandofett, Oct 8, 2016.
  1. Oct 8, 2016 at 2:56 AM
    mandofett
    mandofett [OP] Member
    2008 Tacoma double cab V6
    I have a 08 Tacoma double cab V6. Purchased used from my local Toyota dealer. Thus past weekend I Bagan hearing a squeak coming from under the truck when in reverse. Have checked everything out and it appears my front u joint may be going out. Very slight play in that joint and a line of grease on floor pan above that location. Has anyone here replaced the u joints in their own garage? If so what is the difficulty level? What brand of u joints would be best to buy in the mid level price range? What tools besides a good bench vise and wrenches do I need? Average time to replace one u joint?
  2. Oct 8, 2016 at 4:05 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    Hi I replaced all three ujoints in my garage with just a vise a bfh and some assorted sockets. I used moog ujoints, You need some penetrating oil and some sand paper or emery cloth. It took approx. 90 minutes to replace all three. Mark the shaft so you can put it back in the same position. I would tell you the best thing to do is bring the shaft to a automotive machine shop and let them press the new ujoints in for you . Its not that difficult but its a lot easier to have the shop do it...................good luck let us know how you did....
  3. Oct 8, 2016 at 4:42 AM
    mandofett
    @topcathr what size vise did you use? I have one but not sure jaw opening is big enough.
  4. Oct 8, 2016 at 6:51 PM
    mandofett
    So I stopped by Advance auto and picked up a moog u joint, part 354. Then dropped by harbor freight and picked up a ball joint service kit, BAH, a new set of wrenches, and some needle nose pliers. Hopefully I have everything to do this repair tomorrow
  5. Oct 8, 2016 at 6:58 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    If your going to drop the driveshaft you may as well do all three u joints... no reason not too, I bought my u joints at oreilly for like 11$ each, they are greasable so I figure as long as i grease them regularly they should last a long time.
    As someone mentioned just make sure to mark the driveshaft and yokes at all of the parts that will be separated, after that it is as easy as removing the bolts and dropping the shaft, and popping out old u joints for replacement. I didn't use a vice, just one big socket on the ground, with u joint rested on top and a smaller socket to pound the u joint caps out through the big one. Worked great, took about two hours as it was my first time, could do it again probably in 45 minutes.
  6. Oct 8, 2016 at 6:59 PM
    excorcist
    Reno, NV
    Oh, and also check your center carrier bearing for excessive play, if it is due for replacement now is a good time.
    Also pick up some shop rags as it gets messy, some sort of lubricating oil helps clean things and adds to ease of installation of new u joints.
  7. Oct 8, 2016 at 7:02 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Replace all of it. Do it once
  8. Oct 9, 2016 at 5:03 AM
    mandofett
    Thanks for all the input guys. I would like to replace all of the u joints at once but I have limited free time to do this right now. Also considering this is my first time doing this I wasn't sure how long it would take. Once I get done and see how long it takes me I will plan a day to do the rest. I will already have all the tools needed so I will just need to buy two more u joints
  9. Oct 9, 2016 at 7:09 AM
    topcathr
    2015 limited
    change all 3 now...............you will be doing the job again if you don't. If you don't have the time get them press at the machine shop. I give you credit for doing it yourself, but it maybe easier to get them pressed in a 6 inch vise is plenty. Get ujoints you can grease
  10. Oct 9, 2016 at 7:24 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    OP. How many miles on the U-joints you are replacing?
  11. Oct 9, 2016 at 11:21 AM
    mandofett
    Well got the front u joint replaced. Basically fell apart in my hand when I took old one out. Took me most of the day as this was my first time doing this. Ran into a small issue when reassembling tge joint. I could not get one of the cups on the new u joint to seat properly. Took it back out and found that there was an extra needle bearing in the bottom of the cup. I took this out and checked to see if it had just fallen away from is original location but all of them were there. After this the cup went on just fine. Test drive around the block. No issues with vibration or noise but still when I back up there is a squeak squeak sound.
  12. Oct 9, 2016 at 3:51 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    U joints don't come with extra needle bearings. One fell out and it needs to be in place. Did you grease the others while you were at it? My guess is one of the others is starting to fail too.
    excorcist likes this.
  13. Oct 9, 2016 at 11:43 PM
    excorcist
    Reno, NV
    Either one of the other u joints or your carrier bearing
